Ok try this, save the attached .calz file in to the folder:
C:\Program Files (x86)\EFILive\V7.5\Calibrations\E92
With your V2 plugged in before you start the software, open the tune file and navigate to 'B9903', change to Applied.
You may also need to disable calibration 'G1219', this should stop the need to have a relay wired in to the starter control on the ECM (this prevents them running too).
For B9903 to take effect you must Full Flash the ECM, this only needs to be done once, after than you can continue with calibration only flashes.
Please let us know how it goes.
