Results 1 to 10 of 10
Thread: E38 CAX for "Open Loop Lean Limit" - OS 12628990
    May 2012
    Default E38 CAX for "Open Loop Lean Limit" - OS 12628990
    Hey guys,
    Have been doing some searching and have come up short, i'm trying to find the "Open Loop Lean Limit" table which allows you to set the permissible lean EQ Ratio over coolant temp. The E40's have this PID (B0149) and i'm sure I have seen some E38's with it too. Would anyone know if this table is hidden away and/or have a CAX file to unlock this table by chance.
    Kris
    Jul 2003
    What OS has B0149? I have never seen it.
    Jul 2003
    Try this
    Code:
    [B0149]
    ;         Description
    DESC.001 = Min Open Loop Table
    ;         Seg Caption                          Major            Minor            Vis Dis 2D Grp
    VIEW =      2 "Minimum Open Loop"         "Fuel" "Open Loop"                          1  2   0   0
    ;         Address(es)                      BitOff Bits Typ Inv
    ADDR =    1E179E                                 0   16 UNM   0
    ;         Units    Factor         Offset Prec MinLimit MaxLimit MinUser  MaxUser
    SI_SLOT =  Factor 0.0009765625           0    2   0     4   0     4
    ;         Body           Col            Row
    ULABELS = .              .              .
    ;         Enumerations
    SI_ENUM = .
    IM_ENUM = .
    ;         Units            Labels
    SI_COL =  .
    IM_COL =  .
    SI_ROW =  ECT           "-40,-28,-16,-4,8,20,32,44,56,68,80,92,104,116,128,140,152"
    IM_COL =
    May 2012
    BAM! That did it. How did you work that out? CAX noob here...
    Junior Member GTS 383's Avatar
    Mar 2012
    Hi Highlander,
    That CAX file is the business. I have been looking for something like that. Doesn't work on all E38 OS though. Do you happen to have one for OS 12653249 or one for a OS 12656930. Alternatively, how do I alter the above CAX to suit other E38 OS?
    Peter
    HSV GTS Coupe 6.3Lt LS1, 224/234 @115, 1 3/4" Tri Y, M6, LS7 Clutch, True Trac.
    Mar 2012
    ...other than just renaming the CAX file of course.
    Peter
    Renaming the cax will not work, unless the OS you're renaming it to has that parameter/table at the exact same address, and with the exact same interpretation.
    Mar 2012
    G'day Joecar,
    Yep, got that. So what do I have to change in that CAX to get it to work in those other OS's?
    Peter
    The only way to map it to another OS is to dig through the OS code and figure out where that table exists in that OS.
    Mar 2012
    Hi Erik,
    Yes, not an easy thing I'm sure (certainly beyond my capabilities). Like Kris I was hoping someone had already created a CAX for those other OS's.
    Peter
  1. 01-07 "Gear Indicator Type" cax
    By Lextech in forum CAX Files
    Last Post: December 20th, 2016, 10:58 AM
  2. Replies: 13
    Last Post: July 1st, 2014, 02:38 PM
  3. LMM: Any "Limp Modes" that limit to around 2500 RPM?
    By 8100 Power in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 7th, 2010, 01:47 PM
  4. EFILive "Classic"/"Legacy"/"Historic"?
    By emarkay in forum FlashScan V2
    Last Post: November 2nd, 2008, 02:48 AM
  5. Strangeness with open loop idle lean limit (B3607)
    By turboberserker in forum Custom Operating Systems
    Last Post: February 18th, 2006, 11:14 AM
