all of this to recalibrate my speedo.......
This stuff happens all the time, in all domains... one example (of many): to replace the transmission extension housing seal on my TA, the factory catback blocks the driveshaft, so the catback has to be removed, but the rear axle blocks the catback (since the catback is all one-piece, from the factory), so the rear axle has to be dropped... all that just to change a stupid $1.00 seal that was leaking![]()
but I did get better acquainted with rear axles, differentials, and rear suspensions (and those devolved into another set of tangents) me -><- they
EFILive states they do not support installation on anything but a native Windows computer/hardware. You are using an unsupported configuration and expecting them to understand your unique problem and assist with fixing it. That is not a realistic ask in my opinion. Paul also added functionality to the product to assist you with this issue...
Glad you were able to resolved the issue and thanks for posting back for others.
I need this on a t-shirt!Originally Posted by GMPX
2001 Camaro SS
EFILive Custom OS3
I also do not know how to force the EFILive_Explorer.exe and Hapi to create startup logs, as i do not have the control key on my mac.
