Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: EFI Scripts?
    Senior Member Wolfie's Avatar
    Dec 2007
    Links seem to be broken... all of them...
    Wolfie
    LS1B 2007 Express 6.0 /w 470,000+ miles (parked as of 01April2011)
    Nov 2006
    The Duramaxtuner link in my sig has the .pdf and other links in it.
    LC-1 WBO2
    Quote Originally Posted by Wolfie View Post
    Thanks for the heads up, I'm looking into it...
    Dec 2007
    ok, now some show up, but this one... Ok Guys, Scripts aren't THAT scary.... the pics are not there, and if you click on them it says no permission.
    Wolfie
    You mean the link in this post (in the other thread):
    A great summary of what scripts are and how they work.
    I recently started making my own scripts, and if you try to just make them
    on your own with notepad they can be frustrating to format and run.
    It is much easier for the first time user to let the software make it for you.
    This thread is a perfect walk through for that.
    And the Script_tutorial.pdf should be saved in
    C:\Program Files\EFILive\V7.5\Doc\Tutorials for future reference.
    Post #3 is all you need to know about scripts, thank you vortecfcar.
    I can't see them either, my login at www.dieselplace.com has stopped working...
    Apr 2007
    2011 Chevy 2500HD LML 4x4 LTZ-Black
    -H&S Mini Maxx | MBRP 5" w/Muffler | 4" Rancho Lift | BMF REPR 20x9 DM | Mickey Thompson ATZ P3's 35/12.50's.
    2012 VW Jetta TDI - Daily Driver.
    SOLD - 06 LBZ
    EcoDieselRam Forum
    Oct 2006
    Yeah 'scripts' are pretty handy , made life much easier .
    Simple and easy to use , and saves time .
    2006 Trailblazer
  9. #19
    Dec 2009
    Is this really the case? I didn't see anyone directly comment on this. I ran a script, and only changed the lines other than the OS, will this work? They were both from an 06 LBZ.
    No, my understanding is the tunes you want to compare must be the same OS and have the same/compatible engine codes.
    The only way to see differences is if both tunes are the same/compatible os/engine codes...
    if you can view differences then you can generate a script...
    if they are different then they cannot be compared (my simplistic understanding is the data field offsets/locations and formats/layouts are different relative to each file).
  1. Making Scripts.
    By 5.7ute in forum Tips and tricks
    Last Post: September 12th, 2007, 10:30 AM
  2. DSP5 scripts
    By Lennart in forum General (Diesel)
    Last Post: March 29th, 2007, 03:58 AM
  3. scripts not working right
    Last Post: January 31st, 2007, 08:32 AM
  4. EFILive Scripts
    By Black02SS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 7th, 2006, 11:30 AM
  5. Scripts :D
    By MN C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 31st, 2005, 03:48 PM
