Results 1 to 10 of 14
Thread: trouble getting my lc1 wideband in serial cable to connect and log
    May 2007
    Default trouble getting my lc1 wideband in serial cable to connect and log
    i am actually trying to get new pc working properly. I had to do all the updates through efi live and now I can not get my lc1 to log ben factor. here is my pid file, can someone take a look and see why it wont log?
    1st how do I link a pid selection?
    2000 NBM trans am.
    427 Dart ship block,Lme ported Ls7 heads 12.5 compression
    246/262 .730/.712 112+4 low lash solid roller
    Rmvb 4l80 with transbrake, 8" FTI converter
    12 bolt Moser rear end with 4.10 gears
    May 2007
    ok I have it logging ben . I just cant get the map for lc1 to get rid of the line through it so I can log and see all cells its out. any pointers are welcome, thanks.
    2000 NBM trans am.
    Post some screenshots...
    and a log file.
    May 2007
    Default test to see if log works
    not the best with pc's this file work?
    2000 NBM trans am.
    With map A showing, click the map properties button (7th from left), goto Data tab...
    for Parameter select Base Efficiency Numerator Bank1, Srial Wide Band LS1 Style...
    then click Save, click Ok.
    May 2007
    Only option it gives me is the base efficiency numerator 1 -lc1 ls1 style [factor] -not currently selected
    I can't find the serial one
    2000 NBM trans am.
    May 2007
    Ok i did find it. Now Map A is Ben1 (Average) but has a line through it still
    2000 NBM trans am.
    May 2007
    Got it. Thanks Joe
    2000 NBM trans am.
    Quote Originally Posted by Aint Skeered View Post
    Got it. Thanks Joe
    It's working, it has no line thru it...?
    May 2007
    No line. It's been a long time since I've done ve tuning with the Ben map. Copy with labels then multiply and paste in ve table correct?
    2000 NBM trans am.
  1. Having trouble with LC1 wideband
    By rrmccabe in forum FlashScan V2
    Last Post: May 31st, 2016, 01:25 AM
  2. LC1 serial cable logging??
    By tdmkr496 in forum Gen III V8 Specific
    Last Post: March 4th, 2014, 11:47 AM
  3. wideband serial cable
    By vcls1 in forum General
    Last Post: November 29th, 2012, 03:06 PM
  4. AutoVE with serial wideband Lc1
    By gotabav in forum Petrol / Gas
    Last Post: December 31st, 2011, 07:31 PM
  5. Tried making own Serial Wideband Cable, HELP!!
    By edwardzracing in forum FlashScan V2
    Last Post: March 18th, 2009, 04:54 AM
