Results 1 to 8 of 8
Thread: Mustang PowerDyne Software with EFILive
    Junior Member GM-Josh's Avatar
    Jun 2016
    Default Mustang PowerDyne Software with EFILive
    Question, not to sure if this is a good location for this thread but anyhow. Does anyone use their mustang dyno and powerdyne software with EFILive? There's an option to direct connect to EFILive, just have a few question around setting it up. Using the OBDII splitter with my dyno and efilive is useless.
    Thanks in advanced
    You can't have two scantools running on the same OBD-II plug (eg the Dyno PC and EFILive talking at the same time to the car).
    For EFILive to work alongside a compatible dyno PC the connections are made to the V2 serial port instead. I'm sorry I don't know if that dyno is supported to do this.
    Jun 2016
    I don't use the splitter at all. For diesel I use the OBD-II plug to pull rpm, or use the optical pick-up if data-logging. The powerdyne PC has the EFILive otion in the menu, never noticed it until now. Was curious does it work with the Efilive scan tool while hooked to the serial com port with the powerdyne pc software running? looks as if it uses RPM from the EFIlive software only, not 100% sure will try using it at the end of the day.
    Jun 2016
    If there's anyone on here that uses a Mustang Dyno and software, I have a few questions on some parameters. Can email me at jf36@live.ca or call me I will gladly pay for any long distance phone fees. It would be nice to have someone to talk to about technical topics or work flow, calibrations all that. I have had lots of training in class, books and real world testing, only been operating a dyno for 2 years won't sit here and say I know everything. Just don't know many other operators willing to go back fourth with.
    Thank you,
    Apr 2015
    The DYNO option is missing from V2 Firmware for some time now. Would be nice to have it back.
    Quote Originally Posted by MobileProg View Post
    In the F4->F1-F1 "Edit Settings" option, set "COM Port" to "External" which means Dyno or other external data logger.
    Dec 2012
    Was having this issue as well. After contacting Mustang, they said EFILive was to difficult to work with, so they dropped the project and moved on.
    Josh
    '04 GMC LLY
    ^^ lol ^^
  1. EFILive Software Testing Guidelines
    By cindy@efilive in forum EFILive Beta Software
    Last Post: April 6th, 2016, 06:35 PM
  2. Replies: 2
    Last Post: January 27th, 2012, 03:55 AM
  3. Looking for help 03 6.0 powerdyne supercharger
    By oldblue_6 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: September 17th, 2010, 08:19 AM
  4. Stock LS1 with powerdyne 6 psi kit
    By hotrod in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: October 28th, 2009, 03:07 PM
  5. EFILive FlashScan V8 software WHEN???
    By kbracing96 in forum Lounge
    Last Post: June 5th, 2007, 02:07 AM
