Results 11 to 20 of 53
Thread: Running extremely rich in boost/breaking up
    Oct 2016
    AC Delco 213-1631 2 bar
    Oct 2016
    updated tune and more log files, one in town and one wot throttleupdate1 wot.efiupdate1 town.eficos3 turbo th400 update 1.ctz
    I'll take a look...
    Dec 2014
    Your A0009 is very very rich. Is this a referenced regulator and raises with boost? What injectors are you running? Ditch using B3618 for enrichment and use B3647 so you can command proper out of boost numbers and ramp to boost.
    You are leaning out the main fueling because the MAF is not failing correctly. When the MAF isnt failed right everything will run lean. Some of the OSs do not like the DTC value on non emissions. Switch it to A:1 trip. Also, I would suspect the maf is gone completely?
    Oct 2016
    Completely mafless, running 42 lb injectors
    Dec 2014
    42 what? How is the regulator and rail setup? This will define the shape of the A0009 table.
    I think Team208 is saying to do something like this:
    - B3647: ramp this up to something like EQR 1.22 in the last column;
    - B3613: set this to 105 kPa;
    - B3618: set this to boost fueling (EQR 1.235 is maybe ok, EQR 1.26 is safer during tuning);
    Team208, any refinement on those value...?
    Oct 2016
    Delphi 12613412 injectors. Stock rail and regulator
  9. #19
    Oct 2016
    I’ll take a look at those tables when I get off work and try to do a few more test runs if it quits raining. I really appreciate the help by the way. This is the first boosted application I’ve attempted to tune.
  10. #20
    Do you have a manifold-referenced FPR (what Team208 is asking) above...?
    Measure rail pressure with FPR reference disconnected (remember to reconnect after measuring).
    42 lb/hr injectors rated at what pressure (and what brand are they)...?
  1. running rich
    By derkscustomcars in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: August 30th, 2015, 08:58 AM
  2. Breaking up in Boost Randomly
    By cyipher in forum Custom Operating Systems
    Last Post: June 5th, 2013, 03:28 AM
  3. "Breaking up" when in boost?
    By DrX in forum Gen III V8 Specific
    Last Post: August 15th, 2011, 03:40 PM
  4. Why am I running rich during PE?
    By n8dogg in forum Gen III V8 Specific
    Last Post: August 4th, 2011, 09:31 AM
  5. Why is it running rich?
    By Garry in forum Gen III V8 Specific
    Last Post: May 10th, 2008, 05:05 AM
