Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 53
Thread: Running extremely rich in boost/breaking up
  1. #41
    Oct 2016
    fuel system is a stock return type fuel system. static frp with no reference is 56 psi. injectors are 50lb/hr @ 58 psi. I am currently trying to find injector data sheets for rest of the injector data.
  2. #42
    Dec 2014
    Can you put up the stock COS before modding? When you flash the COS, then flash the stock file, then read... I want that read. I'll help setup
  3. #43
    Quote Originally Posted by mgnta217 View Post
    when setting the ifr, should i set it flat (referenced) or sloped (non-reference)?
    fuel system is a stock return type fuel system. static frp with no reference is 56 psi. ...
    keeping track of details:
    referenced FPR.
    56 psi base pressure mreasued.
  4. #44
    Oct 2016
    2001 Chevy Silverado
    Stock 4.8l engine
    Twin 60mm turbos running 5-8lbs boost
    Return type fuel system with stock rails and regulator (delphi 12613412 injectors 50lb/hr @ 4BAR)
    Reference FRP @ 56psi
    Completely MAFless
    EGR Delete
    EVAP delete
    Catalyst delete
    2 BAR MAP sensor
    TH400 transmission
    Stock COS
    LS1B.ctz
  5. #45
    Dec 2014
    Whats the MAP part number?
  6. #46
    Oct 2016
    AC Delco 213-1631 2 bar
  7. #47
    Dec 2014
    is this drive by wire?
  8. #48
    Oct 2016
    Yes
  9. #49
    Dec 2014
    This is by no means tuned but is a start for a boosted app. I have setup the flex fuel injectors based off a gen 4 ecm. They are set for 4 bar. A few percent low on pressure is not going to hurt, if its all stock parts its normal to have it +- a few psi. YOU WILL HAVE TO LOG AND TUNE THE VE!!!!!! Timing is set safe, 14-15 degrees cool boost and pulls more as temp goes up. If you have a question or are unsure on a setting, ask.
    LS1B - MOD.ctz
  10. #50
    Oct 2016
    I compared yours to the one I have been working on today and I'm glad to see I was on the right track with my injectors, after your help of course. I'm gonna tweak and flash this tune and make some logs
  1. running rich
    By derkscustomcars in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: August 30th, 2015, 08:58 AM
  2. Breaking up in Boost Randomly
    By cyipher in forum Custom Operating Systems
    Last Post: June 5th, 2013, 03:28 AM
  3. "Breaking up" when in boost?
    By DrX in forum Gen III V8 Specific
    Last Post: August 15th, 2011, 03:40 PM
  4. Why am I running rich during PE?
    By n8dogg in forum Gen III V8 Specific
    Last Post: August 4th, 2011, 09:31 AM
  5. Why is it running rich?
    By Garry in forum Gen III V8 Specific
    Last Post: May 10th, 2008, 05:05 AM
