how do i use this spread sheet i understand that you copy and paste the ben's in do i start with copy and pasting the b0101 first and then paste over the top sorry if i missed somthing thanks in advanced
You paste your BENs in the top table, then copy the bottom table and paste-multiply into your VE table.
no worries, feel free to post questions/comments/tol (thinking out loud).
When i did this , it made lots of spikes In my ve table. Suggestions?
2000 NBM trans am.
427 Dart ship block,Lme ported Ls7 heads 12.5 compression
246/262 .730/.712 112+4 low lash solid roller
Rmvb 4l80 with transbrake, 8" FTI converter
12 bolt Moser rear end with 4.10 gears
Ok, maybe then avoid the interpolation spreadsheet;
instead, paste-multiply the BEN into the VE table, and then manually adjust the surrounding un-hit cells to match/flow with the hit cells.
I was just trying to figure out how to use this. Looks like a great idea
2000 NBM trans am.
It works in certain situations. Do it as joecar says.
