I have summit-ed a support ticket also. I have a CM2200 that failed the patch file write and now is setting a $0534 invalid serial number and ecm is dead in the water. Trace files attached.20180525_161944_CMD_F.rar
The controller should be recoverable by flashing a tune file without any security permissions. You should follow the steps outlined here. https://support.efilive.com/kb_artic...7233-PHJN-8346
Cindy
Sent from my iPad using Tapatalk
Mike unfortunately it was Sunday here when that support request came through, anyway the response in the trace file at the end is error $0340, download not accepted (meaning the anti-tuning security is still active).
Because that flash has not been successful the ECM will be in boot mode, if you can please update to the latest software version that would be helpful as we have done some updates to bootmode recovery in that version.
https://forum.efilive.com/showthread...ase-(May-2018)
The beta was superseded by the public release, you will be upgrading not downgrading by using the May Public Release
