Results 1 to 8 of 8
Thread: Calc pid in V7.5
    Jun 2018
    Default Calc pid in V7.5
    I’m trying to create a calc pid for V7.5. Ive tried to create this using instructions from this site, it must be a bit beyond my IQ level. I’m trying to log lambda from an analog wideband. I’m currently logging AFR from this set up perfectly, just want to switch to lambda. I’m using analog input 1 and the formula needs to be: lambda=V*.096+.618. Can anyone help create this or point me in the right direction?
    Hi Jake,
    which wideband are you using...?
    here's an example calc_pids.txt that does the same thing as what you need, but for the AFR brand wideband:
    ( see CLC-00-041 )
    Jun 2018
    Hi joecar,
    Thanks for the reply.
    I’m using a Ballenger AFR500V2
    Quote Originally Posted by Jakemcnall View Post
    Hi joecar,
    Do you have the user manual pdf for this...?
    Is this the same as the ECM AFR1500...?
    What is the stoich AFR that this wideband assumes...?
    Jun 2018
    Jun 2018
    I just nailed it.
    I was using expression: {EXT.AD1}*.096+.618
    Turns out I needed 0s in front of the decimals.
    Changed expression to: {EXT.AD1}*0.096+0.618
    Works like a champ now. Nothing quite like the feeling when you figure something out after messing with it for a long time. Thanks for the reply’s joecar.
    Good job
    that's a real nice wideband.
    Jun 2018
    Thank you sir. It was recommended to me by my remote tuner
  1. calc.pid /sae.generic - pid resoultion question
    By cyipher in forum Gen III V8 Specific
    Last Post: February 6th, 2014, 01:00 PM
  2. Can some help me with a calc pid please.
    By pavetim in forum Diesel
    Last Post: February 4th, 2011, 01:17 PM
  3. calc.pid help
    By mr.prick in forum General
    Last Post: June 1st, 2010, 02:28 AM
  4. e38 dma pid SCALEDCORVE_ doesnt work plus a bad calc pid
    By ringram in forum FlashScan V2 BB Logging
    Last Post: November 30th, 2008, 11:28 AM
  5. hp calc PID
    By pwilson22000 in forum General
    Last Post: July 25th, 2006, 12:58 AM
