Results 1 to 10 of 12
Thread: Increasing RPM & Speed with O Throttle Pedal Input
    May 2009
    Default Increasing RPM & Speed with O Throttle Pedal Input
    I have a 5.3L with 4 speed auto transplanted into a 68 Chevelle that I have tuned. It runs and drives great. When you pull it into gear then let go of the brake with no throttle input the car will start moving and increasing speed even shifting. It seems TAC_PCT% is increasing but I cannot find what is driving it. When coming to a stop and stopping it takes a long time for the TAC_PCT% and RPM to reduce. Attached are engine and trans cals plus a logs.
    Dennis_68_Chevelle_12614085_29June2018_Idle_0014.ctz
    Dennis_68_Chevelle_24238856_TCM_12May2018_0002.ctz
    Dennis_Idle_29June2018_0002.efi
    Dennis_Idle_29June2018_0001.efi
    May 2009
    Interestingly it operates properly when cold, below 80C.
    Thoughts
    I'm looking thru your files to see if I can see what's causing it...
    May 2009
    Thanks Joe
    I’m perplexed
    What year/model/vehicle are your ECM/TCM from...?
    May 2009
    It's out of a 2007 Silverado 1500 the motors a 5.3
    May 2009
    Any thoughts on what could be causing this.
    I'm still scratching my head.
    May 2009
    LOL
    It is a perplexing one :(
    Aug 2013
    Quote Originally Posted by TurboCamaro View Post
    Now there's your problem... a 68 Chevelle requires a 6.0L engine. Installing a 5.3L is almost criminal.
  1. Replies: 16
    Last Post: February 28th, 2018, 06:53 AM
  2. 2016 LML and Increasing speed limiter = no exhaust brake ?
    By staytuned in forum Duramax 2011+ LML / LGH
    Last Post: June 27th, 2017, 01:25 PM
  3. E78 throttle fluctuation with constant pedal position at constant speed
    By motoxxxman in forum E78, E83, E84 PFI ECM's
    Last Post: July 27th, 2016, 09:45 AM
  4. E78 throttle fluctuation with constant pedal position at constant speed
    By motoxxxman in forum E39, E80, E82 & E92 SIDI ECM's
  5. E37 & E67 OS compatability vs Throttle Pedal Sensors
    By Yellow05C6 in forum E37, E38 & E67 PFI ECM's
    Last Post: January 20th, 2015, 06:55 AM
