i.e. not CALC.BEN_LC11.
Joe, we finally made a step in the right direction. The ben from WB is an average of .8064. I'm not sure what I have changed but for some reason on the ben map it is only taking data on the far right side. After filtering I get an average of 0.0. I'll attach some pictures. I ran into this a while back and figured out I was copying and pasting labels wrong but I'm not sure what is causing it this time. I'm very happy with what you recommended.
Can you do something to make combustion go lean, WB should then show lambda greater than 1.00.
In scantool:I'm not sure what I have changed but for some reason on the ben map it is only taking data on the far right side.
- on PIDs tab, on MAP pid, go rightclick->Metric.
- on Maps tab, in map properties, on the Column tab, click Show Units, then select MAP.kPa for the column pid.
Post some screenshots ( hint: try getgreenshot.org to capture screenshots ).After filtering I get an average of 0.0. I'll attach some pictures. I ran into this a while back and figured out I was copying and pasting labels wrong but I'm not sure what is causing it this time. I'm very happy with what you recommended.
where do u live? r u using the v2?
