Hey guys, quick question and sanity check before I pull the trigger. I've read thru all of the newer AEM widebands threads on here. LS1B, so no fast CANBUS logging
Is 30-0300 the 'best' option for me?
Is Analog output still the preferred method over serial? Threads seem to indicate these new x series gauges output analog at 500hz vs 10hz serial. And serial is limited to only tenth decimal place, ie 14.6, 14.7 step size.
Is this still the case?
Thanks guys. I currently have an Innovate LC-2 and purposely converted over to serial to get around voltage offset errors. I read the AEM has built in voltage compensate for analog outputs now?
https://www.aemelectronics.com/files...ns/30-0300.pdf
