Page 16 of 16 FirstFirst ... 6141516
Results 151 to 158 of 158
Thread: Correct IFR tables for LS3/LS7 injectors in Gen III
  1. #151
    Quote Originally Posted by dian View Post
    on second thought, i have no idea what the labels are on the l96. i thought thay were hektopascals. just curious.
    I'm not sure what you mean...?
    The axis is on kPa...
    post a screenshot of what you're seeing.
    ~ posted by phone ~
  2. #152
    Nov 2014
    under l96 i see labels from 128 to 768. the values in the tables are different. but i probably misunderstend something.
  3. #153
    Quote Originally Posted by Whipped383 View Post
    Attachment 20465
    This appears to be the correct file for the injectors in question
    In the tune file attached to post #132 above, the axis of table B4001 has those labels.
    Those labels are injector pressure delta (difference from top to bottom of injector) in kPa.
  4. #154
    So if rail pressure measures 400 kPa (58 psi) (i.e. gauge pressure is 400 kPa, so absolute pressure is 500 kPa)
    then injector pressure delta = 500 - MAP
    so then the usable range of the axis on B4001 are as follows:
    • NA: 408 to 468 kPa (400 kPa has to be interpolated by ECM)
    • 1-bar boost: 308 to 468 kPa
    • 2-bar boost: 208 to 468 kPa
  5. #155
    Junior Member spedracr93's Avatar
    Jun 2016
    In the spreadsheets, the LS1B paste-able tables are labelled.
    The tables in these spreadsheets are great, but don't the numbers only work if the Fuel Rail Pressure is 58 psi?
    Is there a conversion possible to use LS3 injector data at a different Fuel Rail Pressure? Say... 44 psi?
  6. #156
    Yes 58 psi.
    You can scale the IFR table using by multiplying by sqrt(44/58).
  7. #157
    Jun 2016
    Yes 58 psi.
    That makes a large difference. Thanks for the formula!
    58 to 44 is a 12.9% difference.
    Can rail pressure affect Minimum Injector Pulse Width? I realize it's a measure of opening time, but it seems like the volume injected at a lower pressure would be less within that time and a compensation could be to modify that minimum time.
  8. #158
    Quote Originally Posted by spedracr93 View Post
    Yes, scales by 0.871.
    It can... I don't know how to calculate the new minimum.
  1. Correct injectors fixed my issues
    Last Post: May 27th, 2009, 02:12 AM
  2. How to correct WOT for each gear?
    By PRAY in forum Gen III V8 Specific
    Last Post: June 9th, 2008, 08:00 AM
  3. Is this map correct?
    By Loudmouth LS1 in forum Gen III V8 Specific
    Last Post: January 19th, 2007, 01:22 PM
  4. 96lb/hr injectors can be run like stock injectors with EFILIVE!!
    Last Post: July 24th, 2006, 02:14 PM
