Results 1 to 7 of 7
Thread: V2 Goes Blank When I Load A SD Card
    Jul 2018
    Default V2 Goes Blank When I Load A SD Card
    Hi , Im following the tutorial on installing a SD card but the V2 Unit Looses power On lcd screen and I loose
    communication . If I remove the sd card it will power back up . SD card im using is 16gb verbatim
    Jul 2018
    All sorted , the sd card I purchased was not compatible, replaced all good
    Thanks for posting.
    Aug 2018
    Just out of curiosity, what was the SD card that's compatible btw? I plan on buying a new SD card as well.
    I strongly suggest these fat burners for men because they worked for me.
    I don't know what SD card Mr teabags used.
    ( I know SanDisk is ok )
    Nov 2005
    Supported SD Card formats, and SD card configuration instructions are documented here.
    https://support.efilive.com/kb_artic...6425-AKLC-5907
    Cindy
    Jul 2018
    Sorry guys the sandisk 16gb memory card works well
  1. V2 blank screen
    By CDR in forum FlashScan V2
    Last Post: December 1st, 2017, 08:12 AM
  2. Is this PCM blank? E40
    By limited cv8r in forum General (Petrol, Gas, Ethanol)
    Last Post: May 10th, 2015, 01:45 AM
  3. Gauge cluster goes blank.
    By samgm2 in forum FlashScan V2
    Last Post: July 16th, 2011, 11:27 AM
  4. Blank 12200411 PCM
    By joecar in forum Gen III V8 Specific
    Last Post: May 7th, 2007, 08:39 AM
