Results 1 to 5 of 5
Thread: 4l80 swap os numbers needed
    Sep 2018
    Question 4l80 swap os numbers needed
    2007 silverado 4.8
    engine os 12614088
    trans os 24239036
    i just swapped out my 4l60 to a 4l80. transmission came out of a 07 express van. i used the harness needed for the swap. im looking for the os numbers to do the seg swap and i haven't found anything on here i am new to efi live. if anyone has a file i can upload with the correct numbers to make this work it would be great!!!
    I replied to the other thread, here's some more info.
    For T42s, you have very limited 4L80E options. The only vehicles that used them were the Express Vans from 08-10 (iirc), so you have to see if your TCM OS is the same as the one used by the Express (trucks and TBSS you're ok).
    I would look at the 08 Express Van TCM OS and see if that works with your ECM. Otherwise, you may need to change the ECM to an 08 so it can run with the 08 Express Van TCM OS.
    The dead simple way to do this without playing around with the tuning would be to re-pin your harness and run the 4L80E with a 4L60/70E trans segment.
    Dec 2018
    So not all.t42s being used with e38s can be used to flash 80e tune?
    Reason i ask is because i pulled a few t42s from 06+ gm cars that were mated to e38s thinking they can be flashed without any issues.. sounds like i wont be able to use these.. is there a compatibility list of e38/t42s that can be flashed.for.80e
    Basically all T42s can be interchanged, there may be exceptions but I've been lucky thus far. E38/67s and newer are very picky about what OS/cal can be flashed. Think of it this way, the ECM defines the platform (vehicle) and TCM comms protocol and the TCM needs to match that.
    Remember the 4L80E wasn't used after 2007 in trucks and 2010 in vans, so anything after that is going to be hit or miss to determine if the comms that TCM OS is using will work with the ECM for the vehicle.
    Dec 2018
    Thank you very much for that info... i cant thank you enough ����������
  1. 4l80 swap with frost harness without segment swap
    By james workman in forum Conversions / Aftermarket Parts
    Last Post: March 10th, 2017, 04:12 PM
  2. 12216125 4l80 swap help
    By jj5star in forum Petrol / Gas
    Last Post: January 5th, 2016, 06:33 AM
  3. need help with seg swap for a 4l80
    By AllOutPerformance in forum Gen III V8 Specific
    Last Post: November 19th, 2012, 10:42 AM
  4. 4l60-4l80 transmission setting changes needed?
    By 05gmcsierra in forum Gen III V8 Specific
    Last Post: September 10th, 2012, 02:14 PM
  5. Help with 4l80 segment swap!!!
    By EVODRIFTER in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 29th, 2012, 02:48 AM
