Results 21 to 30 of 37
Thread: COS3 OLSD to SemiOLSD
  1. #21
    Apr 2011
    Quote Originally Posted by statesman View Post
    Why are you so obsessed with running open loop?
    I don't have an obsession with it. At the time I started, less things interacting seemed to be better.
  2. #22
    Apr 2011
    I believe I still have the MAF that came with the Eforce, but it's a Gen4 based maf. Probably not compatible with the Gen3 PCM. Will have to look for it.
  3. #23
    Aug 2013
    If you want a really good open loop tune, then you need really good injector data... and very few people have that (just because injectors come with data doesn't mean that the data will be good). Closed loop will clean up any fueling errors and, provided your tune is in good shape to start off with, it has benefits over running open loop.
  4. #24
    Aug 2013
    Quote Originally Posted by Jim_PA View Post
    It's preferable to have a MAF with an integrated IAT.... the IAT controls the conversion of desired airflow from mass to volume (complicated, but that's how it is) and proper IATs will give the PCM better idle airflow targeting. Using the heatsoaked IAT sensor in the supercharger means your PCM will have to do a lot of airflow trimming at idle.
  5. #25
    Apr 2011
    I could move from the IAT MAP to the IAT MAF, no problem. The IAT portion of the TMAP in the e-force is already calibrated in my tune for the LS3/7 IAT signal. Just not sure about the LS3 MAF sensor being compatible with the Gen3 PCM.
  6. #26
    Aug 2013
    It'll work... you just need an adapter.
  7. #27
    Apr 2011
    Assuming you mean a physical adapter... -->? https://www.eficonnection.com/home/p...ctor-pigtail-4
  8. #28
    Aug 2013
    Yeah, a physical adapter to connect to your LS1 harness. The product you linked to doesn't make it clear if that adapter services both MAF and IAT... just check to make sure the one you get does actually service both.
  9. #29
    Apr 2011
    Thank you, will give it a try. --
  10. #30
    sounds like a plan
  1. Help with OLSD idle????
    By johnj in forum Gen III V8 Specific
    Last Post: April 3rd, 2016, 05:03 AM
  2. Help with tune - 2 bar COS3 OLSD
    By ELake20 in forum Custom Operating Systems
    Last Post: October 1st, 2013, 07:18 AM
  3. Need help tuning olsd without o2 sensors
    By 02sierra4x4 in forum Gen III V8 Specific
    Last Post: September 28th, 2009, 04:16 PM
  4. Switch from OLSD to OLMAF
    By Alex99 in forum Custom Operating Systems
    Last Post: February 9th, 2009, 03:54 AM
  5. Just went from OLSD to CLSD, some questions
    Last Post: July 7th, 2008, 07:53 AM
