Results 1 to 3 of 3
Thread: AEM 30-0334 OBDII X-Series Wideband for FlashScan V2 getting to log ARF and set BEN
    Jan 2019
    Default AEM 30-0334 OBDII X-Series Wideband for FlashScan V2 getting to log ARF and set BEN
    Hi quite new to all of this i think i have managed to get it to log afr on a dual wideband setup with the obdII sensors but i cant seem to work out how to get a BEN factor to work and would be good to know if i have set up the afr properly thanks for any help.
    Mar 2015
    Having the same problem. Can’t read AFR on V2
    Sorry, I have been out of town several times already this year.
    Are you connecting the 0334 using analog wiring or CAB bus (the 0333 and 0334 have no serial comm port)...?
    If you're using CAN bus, do you have one 0333 and one 0334 as your dual widebands...?
    Post your FSV2 Options.txt file (I need to see which pids you are logging), and post a screenshot of the V8 S&T BBX display.
    Which ECM...? Which year/model/vehicle...?
  1. The AEM 30-0334 OBDII X-Series Wideband for FlashScan V2 is finally available,
    By dr.mike in forum General (Petrol, Gas, Ethanol)
    Last Post: September 21st, 2021, 09:09 AM
  2. AEM X-Series OBDII Wideband UEGO AFR Sensor Controller Gauge
    Last Post: July 24th, 2017, 08:58 AM
  3. AEM X-Series Wideband - Serial
    By Gregs in forum General (Petrol, Gas, Ethanol)
    Last Post: April 13th, 2017, 08:20 AM
  4. AEM wideband to FlashScan V2
    By T34418L31 in forum FlashScan V2
    Last Post: May 14th, 2015, 12:22 AM
  5. BEN is only for analog, right? How do I log BEN with serial logging?
    By Supercharged111 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 12th, 2009, 06:08 PM
