Results 1 to 10 of 12
Thread: 6L80E tuning question
    Member ToonerSQUAD89's Avatar
    Dec 2018
    Default 6L80E tuning question
    I want to tune my camaro, i bumped up the MPH Pattern B which i normally use about 10% across the board, turned off Torque Management. I have an intake, long tube headers and muffler deletes
    What year/model/vehicle do you have...?
    What are your other mods (engine)...?
    What problems do you see (if any), and what are your immediate goals...?
    Dec 2018
    2010 Chevrolet Camaro SS. Mods are Air Intake & ARH Long Tube 1-7/8 Headers with High Flow Cats, Full Exhaust and Muffler Deletes.
    My goals are firm strong shifting and I hate hate that it shifts into 5th and 6th at lower speeds. i kind of wish it was a 4 speed sometimes.
    With your mods the TCM should already be commanding firm (not harsh) shifts... post your TCM tune here.
    You can edit the shift tables to avoid upshifting at low mph in 5th and 6th... ( note that the shift tables should *not* cross each other anywhere... if any do cross, you should uncross them )... if you move the shift curves pay attention to the rpm corresponding to the end point mph on each curve.
    Aug 2018
    Don
    SOMFormula,
    The forum seems to sometimes truncate posts...
    write your post in Windows Notepad first, and then paste it in a reply.
    Dec 2018
    Default My TCM Tune
    Sorry Here is my attached TCM File
    Aug 2018
    SOMFormula,
    And I’m posting from my phone which probably isn’t helping any.
    Aug 2018
    Quote Originally Posted by ToonerSQUAD89 View Post
    I’m on my phone. But you can do a LOT with the 6L’s. They are far superior to the 4L’s of yesterday!
    There is a “sticky” here on the forum. You’ll want to read it! It explains how the 6L works. You tune the trans THRU the ECU.
    So, higher base pressure will help
    Lower the TQ management about 30%. Please don’t go higher then that!!! You risk damaging the trans if you completely shut off the TQ management. That’s a big no-no! I fix a LOT of botched tranny tunes and have seen several blown up 6L’s because someone shut off the TQ management. I like seeing timing go about -5 between shifts. It makes a cool ass bark when it shifts.
    Set your pressures parameter max settings up! Watch your TQPID in the scanner to make sure your seeing the correct TQ the engine is producing.
    If your moving the stock cam around, you’ll gain more HP out of the L99 and more low end TQ too!
    Also set the TQ management shift to “immediate”
    If you have ANY flaring, weird shifts, or crazy timing curves during a shift, the engine isn’t tuned properly.
    Dec 2018
    Ok awesome ill play around a little and also check the stickies
  1. swapping Camaro 6l80e to Vette 6l80e
    By secrt007agt in forum General
    Last Post: January 31st, 2016, 04:43 AM
  2. Help Tuning 6.2L 6L80E Its retarding timing 0 knock
    By 400ss in forum Gen IV V8 Specific
    Last Post: February 11th, 2014, 04:37 PM
  3. NEED HELP , Trying to calibrate 6l80e.
    By SkywayPerformance in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: March 12th, 2012, 08:37 AM
  4. 6L80E Tuning - Victoria, Australia
    By djc123 in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: December 17th, 2011, 01:11 PM
  5. Intro and 6L80E question
    By Goofyguy in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 15th, 2011, 09:43 AM
