Page 22 of 22 FirstFirst ... 12202122
Results 211 to 220 of 220
Thread: Interesting info on B3702 Injection timing
  1. #211
    Mar 2009
    I think I can handle that.
  2. #212
    Interesting... we'll see what B3703 does.
  3. #213
    May 2006
    Going to play with the calculators when some decent weather breaks. My cam has a good amount of overlap, so I guess I should see a change.
  4. #214
    Mar 2009
    Got some data yesterday, but I goofed and logged LTFTs with and without cam sensor, didn't change the value at all. Will re-engage tomorrow and add STFTs as I ASSume you were after those as well. Fair warning, after yesterday's logs truck isn't looking so hot. Left side ran lean and stayed that way, right side didn't alternate enough so take it for what it's worth.
  5. #215
    Aug 2013
    Yeah, we will need STFTs as well. If it does change anything, the change might be small and only show up on STFTs.
    If the left side is significantly lean, you should probably investigate that before worrying about this experiment.
  6. #216
    Mar 2009
    Wideband lives in the left bank and showed 15-16:1, truck got weird after I corrected CMPRET and did a CASE relearn. It's been getting quirky lately, there's definitely a mechanical issue waiting to be discovered. I really didn't expect the effect to be so significant, the root cause is buried deeper than just a bad O2.
  7. #217
    Oct 2005
    Default resolution/sampling rate
    By utilizing the 2 external inputs of my V1, or with the converted EGR and A/C inputs. Could monitor camshaft, crankshaft sensors as well #1 spark and #1 injector. Does the scanner support enough resolution to get something useful? What is the sampling rate? Kind of like picoscope output.
    97 Vette 6spd, CamMotion Titan2 LS1 cam, TSP 5.3 StageII heads, Vararam intake, Z06 manifold, ARH headers/cats, Z06 catback, Monster Stage2 clutch, 04 Z06 pcv, new style knock sensor(late98 to 04).
    Using FlashScan V1 with NGK-AFX Wide band
  8. #218
    Oct 2005
    Default Boundry value FYI
    When opening a stock 97C5 tune file in hptuners the boundry value is shown and quite different from later values.
    7.22 boundry and 4.78 normal(B3702)
  9. #219
    Scantool logs pids at 10Hz for LS1A/LS1B/P01 and 40 Hz for E38/E67.
  10. #220
    1997/8 LS1's do have various differences compared to later LS1's.
  1. Injection Timing / Pilot
    By Lennart in forum General (Diesel)
    Last Post: January 20th, 2012, 03:05 AM
  2. injection timing after pilot c,d?
    By SGFastMax in forum Duramax LB7
    Last Post: February 3rd, 2010, 03:35 PM
  3. injector Timing {B3702}.... when to tune?
    By Goldfinger911 in forum Gen III V8 Specific
    Last Post: February 22nd, 2009, 08:10 PM
  4. Injection Timing During Cranking
    By thetallengineer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 7th, 2007, 03:48 AM
  5. injection timing
    By 02gmcwaldoch in forum General (Diesel)
    Last Post: March 18th, 2006, 07:43 AM
