Originally Posted by
GMC-2002-Dmax
The SOTF File or as you are referring to it as DSP5 is not 5 tunes, its one tune with a limiter value applied based on switch voltage.
You cannot make only one of the switch positions rumble or hiss and the others do the opposite.
Its not the way that particular setup works, you can pick one or the other for the tunes.
