Results 11 to 20 of 23
Thread: problems with CALC.VET
    In the log file in post #5 the pid CALC.TRIMMING was not selected.
    Otherwise looks to be working good.
    Log shows knock, find out what is causing it.
    I use kPa for MAP, g/s for MAF, g for cylair, g*K/kPa for VE, EQR for fueling, and everything else is Imperial.
    Lifetime Member Tinbender59's Avatar
    Jun 2010
    Well I cant find this??
    May 2014
    I'm assuming he means calc.trimming = calc.cl
    Quote Originally Posted by aaronc7 View Post
    Yes correct, I stand corrected
    ( CALC.TRIMMING is in a newer calc_pids.txt that I'm working on )
    Jun 2010
    Thank you
    Jun 2010
    ok I just checked my PID's and its there "calc.cl"
    Joecar have you gotten your new calc_pids figured out, I would like to give them a try on this stubborn beach!!
  9. #19
    Jun 2010
    ok I think that I am narrowing in on this issue. there are two different tables (or threads on Calc.vet)
    first is here https://forum.efilive.com/showthread...se-of-Calc-VET
    second one is here https://forum.efilive.com/showthread...ntire-VE-Table.
    understand that I have troubles dealing with something that I do not completely understand (at least understand the basic mechanisms of the issue) so as such, I searched out everything to do with calc.vet and built a hard file (printed everything out, and put in a binder) then I study and incorporate it all into a cohesive document, and start from there. could someone explain the differences in these two threads? please? I have! figured out that I should have used one or the other, but I do not understand which one to use.
    P.S. I wish That I understood "basic" language programming!
  10. #20
    Post #1 in the Calc.VET thread contains almost everything you need (follow the links you see in that post).
    Doing Calc.VET is easier than doing Calc.MAFT... Calc.VET is very much like doing AutoMAF (except it addtionally calculates a VE table) (and using EQR and Lambda instead of AFR).
  1. Replies: 83
    Last Post: September 5th, 2023, 12:30 PM
  2. Calc vet.
    By dirtymaxlb7 in forum Petrol / Gas
    Last Post: July 11th, 2016, 11:31 AM
  3. need calc vet help
    By whackem04 in forum Gen III V8 Specific
    Last Post: December 16th, 2012, 09:52 AM
  4. Calc VET
    By pormgb in forum Gen III V8 Specific
    Last Post: August 28th, 2011, 10:39 AM
  5. Calc.VET, VET Map Average is all 0.0?
    By n8dogg in forum Gen III V8 Specific
    Last Post: July 15th, 2011, 02:20 PM
