Thread: Unlock E35B
    Jan 2012
    Question Unlock E35B
    How do I read my 2010 E35B ECM DSP5 tun with V2?
    You can't
    Jan 2012
    Is it encrypted?
    No it's not, the additional area in the flash memory that DSP5 uses is stored outside the area the ECM allows reading from therefore it is not possible to obtain a complete tune that includes all the DSP5 additions.
    Instead of people getting a semi complete DSP5 tune that would brick the ECM if it was flashed back in it was better to just block reading totally.
    Jan 2012
    Does a reg or seed key open the file?
    Quote Originally Posted by mark892 View Post
    Re-read the previous reply, you CANNOT read an E35B DSP5 tune. You have to start with a base file, upgrade it to DSP5, then full flash that in.
  1. E35B Digital MAF Scaling
    By kidturbo in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 14th, 2018, 05:34 PM
  2. LMM(E35B) Table Use Question
    By NCRay in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 29th, 2017, 10:44 AM
  3. Read option for E35A and E35B in V8 Tune section.
    By Brian1 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 8th, 2012, 10:21 AM
  4. E35A or E35B
    By billdmax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 14th, 2011, 01:16 PM
