IMPORTANTThis release saves *.ctz and *.coz tune files using an updated format. All new *.ctz and *.coz tune files that are saved using V7.5.28, V8.2.24, and V2.07.140 (or later versions) will no longer be compatible with older software or firmware versions. Attempts to open a new file using old software will result in error $0525 "Tune file is not compatible with firmware" or "Tune file is not compatible with current software version". Any customer that needs to open *.ctz or *.coz files that have been created or saved using this or a later version of the EFILive software, must also use this or a later version.
Tuners who support remote customers MUST ensure their customers also update to maintain compatibility.
Note: Existing *.ctz and *.coz files saved using previous versions of the EFILive software can still be opened by this and later versions of the EFILive software.
Release Notes:
Version Numbers:After installing this beta release you should have the following software, boot block, firmware versions installed:
- EFILive V7 software: V7.5.28 (Updated June 12, 2019) To view the installed version, select Help->About (in the V7 Scan or Tune software).
- EFILive V8 software: V8.2.24 To view the installed version, select Help->About (in the V8 Scan and Tune software).
- Boot Block: V2.07.008 (Jul 4, 2018) To view/update the Boot Block, click the [Check Firmware] button in the V8 Scan and Tune software.
- Firmware: V2.07.140 (May 26, 2019) To view/update the Firmware, click the [Check Firmware] button in the V8 Scan and Tune software.
Download here:
Known Issues:
Issue #1:
Workaround:
None.
Issue #2:
Workaround:
Issue #3:
When opening *.tun files (or reading controllers) using the V7.5 software an "Access Violation" occurs.
Workaround:
Re-download and install the V7.5 software from the updated link above.
If you have already installed the V7.5.28 software prior to the update on June 12, then the "Check for Updates" will not detect this update - you must download the V7.5 software and re-install.
Note: your old *.tun files can be updated/converted in bulk to *.ctz files using the EFILive V8 software's Bulk Update option. [F8:Tools]->[F6: Bulk Files]->[Update Files].
