Thread: Would like another set of eyes on my calibrations
    Senior Member Naf's Avatar
    Aug 2006
    Default Would like another set of eyes on my calibrations
    I have a 2010 Tahoe, which i tow with, i massaged the trans tune a little, and she feels better, but i have a small problem between 2 and third shifts. Its gets up to the shift point, releases 2nd, but before 3rd has a chance to engage the rpm climbs then it shifts into 3rd and i go about my other shifts...
    Cold, hot, low torque, high torque it does the same thing...
    Lookin forward to all your inputs
    American Muscle, European Design, Japanese Tactics
    Which pattern is being used...?
    Aug 2006
    Either normal or pattern B, i really dont know, thats why they are the same...
    Apr 2019
    I realize this is 2 years old but did you ever reconcile this? I am having the same issues but add in 1-2 as well. Mine is a 2011 Tahoe rebuilt motor and 3000 Stall. Also attached is the motor tune.
    ModTCM.ctz
    ModECM.ctz
    Aug 2006
    Quote Originally Posted by Smashertron View Post
    So i was told to rise the min spark, my gear shift issue was happening between 3000-4000rpm, i lowered the min spark and it seems to have cured my ghost issue where in between shifts the rpm climbs then engages.
    I worked it where everything below 4000rpm has -5 as the lowest, and everything above 4000rpm i have it as -10 instead of -25.
    let me know if this also cures your problem
    Apr 2019
    Naf, thanks for the response!!! I will check on this also. Mine is a little different scenario but checking everything helps. I will follow up when I get this figured out.
  1. reduced engine power p1514 KOER set at idle but P1518 set KOEO
    By megadeus in forum Gen III V8 Specific
    Last Post: April 11th, 2015, 08:58 AM
  2. Website for calibrations
    By J.Abbott in forum Gen IV V8 Specific
    Last Post: February 20th, 2013, 11:05 AM
  3. MAF calibrations
    By pullincrazy88 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 30th, 2009, 11:06 AM
  4. LBZ Calibrations
    By Ultimate Diesel in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 25th, 2008, 11:44 AM
  5. OS Calibrations
    By Spindoctor in forum General (Diesel)
    Last Post: May 7th, 2008, 11:11 AM
