Results 1 to 10 of 14
Thread: $0101 During Crank
    Aug 2016
    Default $0101 During Crank
    Good afternoon all,
    I am working on an E92 4.3 swap in an 86 Camaro. I'm in the process of trying to get this started, but have no spark/fuel. I've already done the VATS delete as instructed, so now I'm trying to log some information during crank. Twice I managed to get some live data while cranking, but now I keep getting $0101 as soon as I hit the key to crank. The FlashScan screen also goes blank at the same time. Does anyone have any ideas as to why it appears to disconnect each time I crank? Is there a minimum voltage that is needed during crank to keep it connected?
    Thank in advance
    Aug 2016
    Default No Spark
    I'd like to add a copy of the tune file in case someone wants to have a quick look for me.
    Quote Originally Posted by RC1 View Post
    Sounds like the power to the OBD-II plug does not have a direct +12V battery feed to it, instead it is being cut off when you crank.
    Aug 2016
    It is being fed directly, but there is a drop to about 9V when cranking. Not sure where the threshold is supposed to be.
    Off the top of my head 9V sounds like the minimum voltage the V2 can run from. But it seems to be dropping a long way, even under cranking (assuming the battery is in good condition).
    Aug 2016
    The battery is new and it does crank at a good speed. I'm going to run another feed to the OBD port tomorrow and see if that helps. Then maybe I can log while cranking to see what's going on. Thanks for the response.
    Aug 2016
    I did manage to get in a few crank logs before the dreaded $0101 again. I am seeing IGN1ON for the #1 coil control circuit goes to YES, but still no spark. After about 3 or 4 logging cycles, the voltage drops low enough to momentarily shut off the FlashScan at which point it goes to $0101.
    Can someone have a look at the attached picture of the Anti Theft Log and tell me if anything looks wrong? Thank you.
    I don't believe the theft PID will give valid status the way the patch works.
    Aug 2016
    I'm back to trying to get this to run, as the last few weeks have been reassembling the rest of the car. Do you know what that IGN1ON PID is supposed tell us? I'm trying to decide whether maybe I have a bad ECM. That IGN1ON is a YES while cranking according to the log.
    Aug 2016
    Currently logging Crank Sensor, Cam sensor, Spark Advance, MAF, and all alooks good, but still no spark. Anything I can add to help me out?
  1. Error 0101 code
    By Jaredlpickett1991 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 14th, 2015, 07:24 AM
  2. LML ECU 0101 and 0322?
    By engr7581 in forum Duramax 2011+ LML / LGH
    Last Post: May 4th, 2015, 11:02 AM
  3. First time flashing $0101 error
    By Butch in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 13th, 2014, 01:12 PM
  4. Need help ASAP. $0101 no data recieved error
    By cat_dr. in forum FlashScan V2
    Last Post: May 11th, 2013, 07:23 AM
  5. Having some issues with BBR. $0101:No Data Recieved
    By BlackGMC in forum FlashScan V2
    Last Post: October 19th, 2009, 12:48 PM
