Results 1 to 3 of 3
Thread: LMM ECM Replacement Question
    Aug 2019
    Default LMM ECM Replacement Question
    Hello, I'm new to the forum and relatively new to EFI Live, having only used tuning companies' tunes vs designing our own for a little over 2 years. I have an 2008 Chevy 2500 that has lost one of the 5V reference outputs as well as the ground for the Wait To Start Lamp and have water intrusion into the ECM case so we plan to replace the ECM. Can I install a used ECM from another truck and flash the VIN to match? Licenses go by the serial number of the ECM not the actual VIN, correct? So I will need a new VIN license, yes?
    Thank you in advance!
    Adrian
    I'm not as familiar with Duramax stuff, but for GM gas stuff of that era, it's better to have a fresh flash with the correct segments for your vehicle from Tis2Web. You would probably be ok finding a same year ECM and swapping it in, then finding a file that matches your VIN (maybe your stock tune) and segment swap the necessary segments to match (things like System and Fuel tank come to mind).
    Yes, licenses are tied to the specific controller serial so you will need a new VIN license.
    Adrian, if you are just replacing the ECM, we supply new and used replacements. You can send us the file you want in it, or we can install your factory file from the GM database. If you want to play with it, you will need the new ECM (serial number) licensed. The efilive staff has been understanding about ecm failures if you want to license it.
    Custom Tuning Services
  1. Do I need to buy another tuning license for a replacement ecm? Damaged ecm
    By mvvette97 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 15th, 2016, 12:11 PM
  2. New ECM ? Have question bout vin license an efi live to new ECM
    By Collins in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 15th, 2012, 10:19 AM
  3. Need LBZ ecm, willing to give immacculate LMM ecm as exchange
    By badassmax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 9th, 2011, 04:20 AM
  4. LMM ECM replacement questions
    By rcr1978 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 22nd, 2009, 12:18 PM
