Results 1 to 9 of 9
Thread: ls7 afrs
    Nov 2014
    Default ls7 afrs
    looking at the stock tune on a 07 z06 in power enrichment lambda goes as low as 0.75 and levels out to 0.78 on top. checking with the wideband, the engine does exactly that. why does the ls7 need so much fuel? this is deep into fi territory, i run around 0.77 @ 1 bar on the ls1. how much can this be leaned out and still be "safe"? i would like to do 12.6, but im scared, its 10% less fuel.
    Post logs and tune.
    What are your engine mods.
    Check rail pressure.
    Nov 2014
    joe, the car is stock, untuned (yet).
    Dec 2014
    Its fine to change, its a non DI NA engine. Is there still cats on the car?
    Nov 2014
    everything stock. so can i go 12.6 on top and maybe 12.4 at torque peak?
    Dec 2014
    How is the car going to be used? Daily, cruising, racing?
    Nov 2014
    for fun and track (circuit) a few times a year. it would not be a problem to richen it up for the track. available gas is 95/98/100 ron. it has upgraded radiator.
    Edit B3618 PE table, keep an eye on wideband AFR... if you're going to race, get some dyno time to see what AFR does at peak power and peak torque.
    Jul 2003
    Its that way to lower exhaust gas temperature and to make it live under the most grueling conditions. Aside from that, it is rated at 505 when it is clearly capable of a lot more. So it is track ready. Don't touch it. Leave it as it is and enjoy the car for what it was intended.
    That being said.. There could be from 30-50whp on the cal alone.
  1. 05 Silverado 5.3 Ol/CL afrs dont make sense
    By camaro10 in forum Gen III V8 Specific
    Last Post: September 1st, 2015, 04:52 PM
  2. AFRs
    By pormgb in forum Gen III V8 Specific
    Last Post: November 12th, 2011, 11:00 AM
  3. Scenning just AFRs
    By oztracktuning in forum General
    Last Post: May 15th, 2006, 12:12 AM
  4. AFRs and Turbos
    By oztracktuning in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: April 27th, 2006, 03:44 PM
  5. LM-1 AFRs in Scan off the scale.
    By curtbriggs in forum General
    Last Post: December 24th, 2005, 06:25 AM
