Results 1 to 3 of 3
Thread: Reading AutoCal Tune File
    Sep 2018
    Default Reading AutoCal Tune File
    I'm working with a LB7 that has ATP DSP5 tunes on it. After doing some extensive work to the truck which included not putting some of the parts back on (this is a California truck), I was wondering if I can read the AutoCal tune file to see how the egr is set. I only need to see what was changed, not anything else. Thanks!
    You can try, but the likelihood is the tune file is set to read-only so even with the file, it will not open and display any tune/calibration information. Connect AC to PC, go in like you'd load a tune via EFILive Explorer, find the tune and drag up to the desktop screen in top half of EFILive Explorer.
    Mar 2009
    I believe you can do the force read on an lb7 like you can an ls1b, but it involves opening the ecm up to do it.
  1. autocal tune file problem
    By sdjames in forum AutoCal
    Last Post: March 18th, 2015, 11:46 AM
  2. Replies: 2
    Last Post: March 13th, 2013, 10:29 AM
  3. Code 0536 tune file not registerd to autocal device
    By manny sts v in forum AutoCal
    Last Post: January 10th, 2013, 11:47 AM
  4. Reading AutoCal logged Data
    By rickp in forum AutoCal
    Last Post: November 19th, 2012, 04:49 AM
  5. reading tunes with autocal
    By romig in forum AutoCal
    Last Post: March 15th, 2012, 01:55 AM
