Page 13 of 14 FirstFirst ... 311121314 LastLast
Results 121 to 130 of 134
Thread: Volunteers needed for E38/E67 Calc.VET project.
  1. #121
  2. #122
    Oct 2010
    Any more progress? Is there anything else I can help with?
  3. #123
    We both got some stuff going on (particularly family stuff)... pretty soon we'll be spending more time on this.
    In the meantime post a few logs and your calc_pids.txt.
  4. #124
    *CLC-00-110
    factor 0.5 1.5 .4 "iff({EXT.AD1},{CALC.EXT_AD1_WBO2.lambda},{EXT.WO2 LAM1})/{SAE.LAMBDA}"
    That is a good idea you have... since you may not get perfectly zero analog voltage, you might try something like this:
    factor 0.5 1.5 .4 "iff({EXT.AD1}>0.2,{CALC.EXT_AD1_WBO2.lambda},{EXT.WO2LAM1})/{SAE.LAMBDA}"
    but it's still a clever idea (automatically selects the wideband connection mode).
    That reminds me: I have to see if there's and abs() operator.
  5. #125
    Do you have 1 or 2 widebands connected...?
  6. #126
    Jun 2014
    can i help
    i have a 2009 g8 gt
    i have a innovate lc2 and bosh wideband
    i ordered a null modem from efi live do i need this or use a different setup ??
    what settings to modify for proper logging pe afm etc.??
    what calc.pids text file should i use?
    log which pids?
  7. #127
    Quote Originally Posted by nick123 View Post
    can i help
    i have a 2009 g8 gt
    log which pids?
    Can you read the Lambda from your wideband...?
    Can you log SAE.LAMBDA...?
  8. #128
    Aug 2013
    Digging up an old thread.
    I know that it's been a while and people move on, so I'm not sure how much demand there is anymore for an E38/E67 Calc.VET but if people still want to try to get a Calc.VET working then I think that I may have found a way to do it.
    To know for sure if my idea will work, I'll need two volunteers with basically the same engine, but with different cams. If you have time to do some logging and want to help, then post your engine specs and hopefully we can find two people with engines similar enough to get something happening.
  9. #129
    Junior Member pir4te's Avatar
    May 2011
    Hi Statesman
    My engine is out at the moment, keen to continue where we left off once fitted.
    Likely new year.
  10. #130
    Dec 2016
    I would be glad to help in any way I can. The only vehicle I have that might do a cam change is an E67 gmpp 525hp so I might be able to do a before and after on that one if it will help.
  1. Replies: 83
    Last Post: September 5th, 2023, 12:30 PM
  2. Volunteers needed for E38/E67 Calc.VET project.
    By statesman in forum Gen IV V8 Specific
    Last Post: May 30th, 2016, 09:19 AM
  3. E40-E38-E67 B5101 Calc Error?
    By TBMSport in forum E37, E38 & E67 PFI ECM's
    Last Post: October 24th, 2011, 04:34 PM
  4. Calc.VET, VET Map Average is all 0.0?
    By n8dogg in forum Gen III V8 Specific
    Last Post: July 15th, 2011, 02:20 PM
  5. E67 & E38 pinouts needed.
    By nycblazer in forum E37, E38 & E67 PFI ECM's
    Last Post: March 6th, 2008, 04:36 AM
