Im putting this into two sections, not sure which is more appropriate but here we go, Guys I got a question. I'm tuning my 2010 Camaro A6. I got my BEN Map finally setup E38 controller in Speed Density, following swingtan's guide. Now here are my issues
First I'm driving an auto and has a manual option with the paddles so am I driving in Auto only logging my BEN or do I hold gears and log? Because the Map Ben outcome is totally different if I drive each way.
Secondly applying the BEN doesn't seem as easy as it seems. If apply the BEN's to the cells, what do I do about the adjacent cells? The tune never seems to get tighter only more skewed. Ive turned off P.E to just the tables to 1 Lambda. When I have this dialed in, I can reinstate lambda and do a WOT run and adjust.
How do I get more table resolution in each zone What does zone edge alignment do? I want to know Exactly what it means and what it does.
