Is there a way to tune 02 silverado 5.3l/4.l60e ecm to accept a single wire park/neutral on pin 34?
The Camaro is setup that way. There is a gear indicator CAX file which should allow you to make this change.
found the cax files. thanks
Location of the cax files? Please? I'm having this same issue
