Thread: 7.4L vortec black box
    Sep 2017
    Default 7.4L vortec black box
    I recently bought a project car that has a brand new, bone stock 454 engine in it. The computer running it is 16244210. I've gotten as far as finding out to tune it I would need a a 0411 pcm and that I would need to contact Lextech for a pinout. I've tried to contact lex via multiple sites with no response. Most of the forums doesn't have him being logged in for a good 6 months now.
    I plan on sticking a zz502 cam in it, although I haven't done much research, that's down the road. The trans is a 4l80e and I need to find a cheap solution to correct the gear ratio. I've never played with tuning software, not sure what the expense would be for a cable and software.
    Hopefully the lights are still on in this subforum - this engine and swap is a bit dated now.
    thanks
    I'll send him a pm on your behalf (the forum won't let you do pm's until your post count reaches 10).
    Aug 2006
    Jeepster,
    You aren't set up to receive PMs either. I just tried. Go to the "Profile" section and check to receive messages/PMs.
    Jeff
    98 GMC RCSB 2WD, Internally stock 305 w/Twin T-3 junkyard Turbos,4L80e,Ramjet intake,42lb.inj., 0411PCM, COS3,4675LBS w/me in it. Best Time on 5 passes-13.01@110
    Sep 2017
    Thanks joecar!!!
    Hi Jeff, I had no luck turning on PM's. Please contact me -edit no need to my email to be here
    Aug 2006
    Got it.
    Jan 2020
    Lextech i need info please Sir. I sent you messages looking for help with 2000 k3500 7.4l 4l80e 4x4 to 0411 pcm / Blackbox Swap
  1. Black V2 box VS Blue V2 box
    By realstreet in forum FlashScan V2
    Last Post: June 3rd, 2014, 10:35 PM
  2. V2 black box computer cannot recognize black box?
    By ecc_33 in forum FlashScan V2
    Last Post: June 16th, 2011, 11:12 PM
  3. Vortec 350/ Black box
    By 99TransAmls16spd in forum Vortec V6/V8 Specific
    Last Post: December 11th, 2009, 06:15 PM
  4. SD on a black box OS?
    By Supercharged111 in forum Vortec V6/V8 Specific
    Last Post: April 12th, 2009, 04:50 AM
  5. V2 Black Box data logging*vortec pid's*
    By GAMEOVER in forum Vortec V6/V8 Specific
    Last Post: October 7th, 2008, 05:01 AM
