Thread: E38 DVT fuel composition reset
    Lifetime Member Gregs's Avatar
    Sep 2008
    Default E38 DVT fuel composition reset
    Just want to verify that i'm reading this correct, we should only click reset if the ethanol percent is less than 10% but greater than 0%. Here is a pic of the button in the DVT control panel.
    03 Silverado 5.3 ECSB 4x4 Z71
    Comp Cam 206/212 .515/.522 112 lSA, hardened rods with LS9 springs
    2010 Tahoe VVT AFM 5.3
    Stock for now
    Yeah I think that was correct (less than 10%), the sensor recalibrates to a non ethanol fuel.
    Sep 2008
    Thanks,
    I see there is a toggle button in the tune to specify calculation vs physical sensor. Does anyone know if it's possible to convert to a real sensor and which pins on the PCM I would need to connect to?
    Stock for now
    Yes, a pretty common thing to add an actual sensor as the "virtual" sensor kinda-sorta works. GM did it to try and remove the physical sensor cost, but I believe they added it back on later vehicles (don't quote me on this part). On the E38, the signal pin is pin 40 on the black X1 connector (there's a good writeup on g8nation as well). Make sure you change the sensor style to physical, and copy all the FF values over from a factory FF tune.
    I'm in the midst of doing this on my Sonic (E78) so I can run E85 on it.
    Sep 2008
    Thanks for the info, i will checkout the writeup on g8nation. It's too cold to do a conversion in an unheated garage right now. I may end up disabling flex fuel until this spring when it warms up and I can do the conversion to an actual sensor.
    A couple weeks ago I ran the tank nearly dry and filled up with E0 fuel. Reset the fuel composition. I noticed that the reset would set the fuel composition to 3.3% ethanol. As I've been driving around for the last while the number has slowly been trending upward. It's currently at 14% with E0 fuel! I'm going to start doing some poking around online to see if anyone understands the calculated formula that it's using. I suspect the computer's increasing fueling to bring the LTFT's into the 0 to -2 range.
    Stock for now
    The physical sensors are relatively cheap now, about $50 or so.
  1. reset fuel trims
    By nick123 in forum FlashScan V2
    Last Post: May 11th, 2015, 02:54 AM
  2. E38 octane scaler reset
    By 67SS509 in forum E37, E38 & E67 PFI ECM's
    Last Post: March 16th, 2013, 02:49 PM
  3. How to reset long term fuel trims?
    By Hulkss in forum Gen IV V8 Specific
    Last Post: November 8th, 2010, 05:25 AM
  4. Programming out fuel composition sensor?
    By camy in forum Gen III V8 Specific
    Last Post: January 17th, 2009, 12:45 PM
  5. E38 dvt
    By PSWired in forum Gen IV V8 Specific
    Last Post: September 7th, 2008, 09:14 AM
