Results 1 to 5 of 5
Thread: COS question for LS1B
    Jan 2007
    Default COS question for LS1B
    I have a technical question about COS. I have a 2003 Sierra with the LS1B operating system. I believe 12579405 if it matters.
    Anyways my question is about turning off the MAF. It came to my attention while reading the tutorial that the MAF needs to be disabled while running a COS. I would like to keep the MAF but feel like I need to obtain a VE table that can read up to 8 lb of boost. Does anyone know why? Is it a technical limitation of the OS? Will it screw up the fuel calculations? If it leave it on will the OS just ignore it?
    I will admit I am not educated about why this decision was made or forced. It just seems like the MAF would be nice to have with COS.
    Can anyone shed any light on this situation??
    May 2014
    MAF works fine on COS. I think the guide just assume you are going SD. I ran COS3 for a while before converting to SD.
    Jan 2007
    Good to know. I will try it then. The guide does read as though the MAF will be disabled and not an option. Probably just an oversight as you are suggesting.
    COS is able to run the MAF...
    but with boost, the MAF will run out and peg.
    Jan 2007
    Thank you for your many years of helping others. I have it in COS right now with MAF disabled. I used the MAF at least to help tune some of the VE and then cut her loose.
  1. LS1b semi-closed loop operation question (B3647)
    By RamAir in forum Custom Operating Systems
    Last Post: September 18th, 2024, 10:23 PM
  2. cos 5 on ls1b 411 n20 monitor not working
    By Age08 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: May 27th, 2015, 10:44 AM
  3. COS 3 Question
    By DrkPhx in forum Custom Operating Systems
    Last Post: June 14th, 2010, 01:45 PM
  4. COS 5 Question..
    By tatasta in forum Custom Operating Systems
    Last Post: July 12th, 2009, 03:06 PM
  5. COS 5 question
    By bmax in forum Custom Operating Systems
    Last Post: June 11th, 2009, 05:58 AM
