Results 1 to 4 of 4
Thread: Express Van file with 4L60 needed.
    Default Express Van file with 4L60 needed.
    I have a customer that 5.3 swapped a v6 04 Silverado truck. He converted it a Cable throttle body setup and pinned the ECM. The 1mb Express Van is what we use that will run the IAC valve still. Issue I ran into is all my Express Van files are 4L80 and truck has 4L60, with no like OS I can't segment swap it. Anyone have a work around or a van file that has be swapped? Current OS is 12587811 from 06 Express Van, but I can use any OS from van that will run the IAC. Thanks!
    This may work for you. It is not a DBC file though.
    Al
    Al, thanks.
    Aug 2017
    do you still have the original file with the 4L80E? I been looking for that with os 12587811
  1. 2017+ Express van 2.8
    By DURAtotheMAX in forum E98 2014+ Diesel ECM
    Last Post: January 27th, 2022, 03:43 AM
  2. 2006-7 Express van flex fuel file
    By Illegal Vette in forum Gen IV V8 Specific
    Last Post: August 5th, 2017, 11:54 AM
  3. Needed - 2013-2014 Silverado/Express 6.0L stock file
    By gixxer92 in forum E37, E38 & E67 PFI ECM's
    Last Post: June 28th, 2017, 07:24 AM
  4. 2004-2005 5.3 Express Van stock file
    By SkinnyPedal in forum Gen III V8 Specific
    Last Post: September 14th, 2013, 12:55 PM
  5. '03 Express van 6.0L in '00 S10
    By Sherk in forum Gen III V8 Specific
    Last Post: June 5th, 2008, 06:46 PM
