Results 11 to 20 of 26
Thread: V3 Hardware and V8 Editor
    This information is subject to change. It documents our planned roadmap, due to circumstances beyond our control these plans and time-lines are subject to change (i.e. Covid-19 mitigation policies).
    Release Dates:
    • AutoCal V3 devices are scheduled to begin shipping in the next two weeks.
    • FlashScan V3 devices will start shipping sometime after that (probably 3-4 weeks later), depending on field testing results for the FlashScan V3 devices.
    Pricing:
    • TBA - similar to existing V2 prices.
    Hardware upgrades:
    • Upgrade discounts will not be provided.
    License upgrades (FlashScan only):
    Streams:
    • Existing FlashScan V2 stream licenses may be transferred to your new FlashScan V3 device. The transfer process will cost $99 plus shipping and your FlashScan V2 and V3 will need to be returned to EFILive for the transfer to be performed. The stream licenses will be removed from the V2 device and added to the V3 device. Both devices will be returned to the customer.
    VIN Licenses:
    • Used VIN licenses may be transferred from your existing FlashScan V2 to your new FlashScan V3. You will need to email a "license backup file" to EFILive. That license backup file contains your FlashScan V2's VIN licenses. EFILive will email back a "license upgrade file" that may be used to add those FlashScan V2 VIN licenses to your FlashScan V3. The used VIN licenses are not removed from your FlashScan V2.
    • The VIN license transfer process can only be performed once per FlashScan V3 device.
    • Unused VIN licenses cannot be transferred to your new FlashScan V3.
    Lifetime Member Road's Avatar
    Feb 2015
    [QUOTERelease Dates:
    [LIST][*]AutoCal V3 devices are scheduled to begin shipping in the next two weeks. [*]FlashScan V3 devices will start shipping sometime after that (probably 3-4 weeks later), depending on field testing results for the FlashScan V3 devices. [/QUOTE]
    Are the V3 Autocals available, if not you have a eta?
    Thanks for the info on transferring licences.
    Quote Originally Posted by Road View Post
    Are the V3 Autocals available, if not you have a eta?[/QUOTE]
    AC V3 scheduled to start shipping on Tuesday 2nd June.
    May 2010
    I have 4 FS2 could I transfeer all my licens to V3 with all streams I have ?
    EFILive Tuner
    Assuming all the VIN licenses from your 4 V2's fit on a single V3 (600 limit) then yes, that is technically possible. We are still working out the actual procedures required to do that. It will most likely be handled via emailing license backup files of your old V2's to EFILive and EFILive emailing back a VIN license import file for you new V3.
    For transferring streams from V2 to V3 you will be required to return your V2 to EFILive so the streams can be transferred off of the V2 and onto the V3.
    However, FlashScan V3 will not be available for 4-6 weeks. Only AutoCal is available from next week.
    May 2010
    I hope you could find a way to increase the limit size for the maximum licenses .
    It will not handle 4 V2 ( each one have 221 lincens ) so arround 884 licenes
    EFILive Tuner
    Feb 2015
    AC V3 scheduled to start shipping on Tuesday 2nd June.[/QUOTE]
    That you. I Have 60 on order. Hopefully I am at the front of the list.
  9. #19
    Due to some last minute technical problems, AutoCal V3 shipping has been delayed until next Monday 8th June.
    Apologies for the delay, we were so close to releasing today. However, we have decided to err on the side of caution and take some time this week to re-test the the AutoCal devices to ensure the problems have been fixed properly.
  10. #20
    Feb 2018
    Will the V3 still be able to have external analog inputs (0-5v for wideband, etc)?
  1. What hardware/software do I need exactly?
    By BBPanel in forum Purchase and Shipping
    Last Post: July 29th, 2017, 09:19 AM
  2. T43 Hardware
    By ProperTuningOG in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: September 28th, 2016, 11:44 AM
  3. EFILive V8 Gauge Editor Tutorial
    By LastCall in forum General
    Last Post: April 13th, 2016, 04:08 PM
  4. Resudual Value of V1 Hardware
    By nco663 in forum Lounge
    Last Post: August 24th, 2015, 02:15 PM
  5. Problems linking the scanner and the editor
    By Dirk Diggler in forum General
    Last Post: May 26th, 2005, 04:42 PM
