Results 21 to 30 of 40
Thread: struggling newbie needs direction
  1. #21
    Aug 2013
    jeeper, your fuel trims will work better if you connect your bank 1 O2 sensors to the exhaust on the left side of the engine (drivers side). Bank 2 is the right side of the engine.
  2. #22
    Member jeeper's Avatar
    Oct 2018
    Thanks statesman. I remember looking up what side they were supposed to be on after I posted in that other thread and I have not changed it yet. I will start there for sure.
    2002 Duramax
    project Jeep Wrangler to CJ conversion with a LS engine and 6L80e transmission underway
  3. #23
    Oct 2018
    So I did another quick run after swapping the O2 sensor inputs around. I will say the AFR did improve slightly on my warm up ride, but the overall results are similar to before. This leads me to start wondering if maybe the formula is incorrect from my WB. The calc_pids.txt I copied from was actually from another WB that isn't exactly like mine but I thought may work. I'm guessing the lambda equation may be wrong though. I'm going to try and modify it.
    2002 Duramax
  4. #24
    Oct 2018
    No change after modifying my calc_pids.txt. What am I missing?
    2002 Duramax
  5. #25
    Aug 2016
    Can you attach a copy of your calcpids file?
    Sent from my Pixel 3 using Tapatalk
  6. #26
    Oct 2018
    This is my current calc_pids.txt. I am renaming it and attaching it here so I don't get confused by it.
    I'm wondering if I don't have the proper understanding of how this works. My 30,000 foot assessment is the calc_pids.txt tells the software what hardware to look for and how to use the data from that hardware once (or during) the data is collected? And if this assumption is correct which part of the calc_pids.txt is getting used to calculate the new VE table data?
    Edit: after further consideration it seems likely it's the calc.selben portion? If so it would make sense (assuming I understand the theory correctly) that in my calc_pids file the calc.selben is listed in % and it is first in the file. Maybe that needs to be either removed or relocated?
    2002 Duramax
  7. #27
    Aug 2016
    I made a few small changes to your text file as follows:
    1. Moved your definition of your wideband to chronological order (30 before 32).
    2. Added AFR as a unit.
    3. Removed CALC.AEM.LAM from two of the expressions and used the explicit calculation for the lambda of your AEM calculation.
    4. Updated the calculation for PID 110. It was using the external WO2 PID, not your AEM calculation.
    See if that helps.
    GB-current_calc_pids.txt
  8. #28
    Oct 2018
    Thanks Bob. I was just in process of reading how to create the pids using the Auto VE tutorial. It spells it out pretty good so far.
    One thing I noticed when I put your file in place was an error "duplicate AFR unit". I commented out the AFR under *UNITS and can open the software now but I didn't see a duplicate entry for AFR in the file. I couldn't understand why it was giving me an error for it. I even did a search for it using "Ctrl + F" and let the computer find all instances of "AFR". It didn't list any duplicates...Then I read the explanation tab of the error. I assume it will work without the added AFR unit. I will try it tomorrow and report back.
    Thank you for the help. It is really appreciated.
    2002 Duramax
  9. #29
    Oct 2018
    I'm guessing I still don't have a proper formula.
    2002 Duramax
  10. #30
    Aug 2016
    Can you make a map that shows your wideband's AFR or EQR plotted against RPM and MAP? This should show if you're seeing reasonable values from your wideband.
    Also, are you applying the CALC.VET filter mentioned in the tutorial and replotting your map?
  1. E39A Struggling for power?
    By Buzzer in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: March 13th, 2016, 04:20 PM
  2. New to Tuning, Struggling with VE adjustments
    By rbp4u in forum E37, E38 & E67 PFI ECM's
    Last Post: June 4th, 2015, 12:51 PM
  3. Requesting guidance in direction of minor tune (newbie)
    By sonicgroove in forum Gen III V8 Specific
    Last Post: January 31st, 2013, 09:24 PM
  4. Newbie looking for direction
    By rizaptor in forum Duramax LB7
    Last Post: June 9th, 2012, 01:56 AM
