After using the SD Card via Windows (I presume Windows 10), I think Windows may create a "System Volume Information" folder automatically in the root directory of the SD Card. It may be a hidden folder, so you'll need to change Windows Explorer's settings to make hidden folders visible. If you do see that folder, try deleting it, then ejecting the SD Card, then try it in FlashScan V2 again.
