Results 1 to 8 of 8
Thread: E38 Auto to Manual Conversion - Reverse Lockout Enable
    Dec 2019
    Default E38 Auto to Manual Conversion - Reverse Lockout Enable
    I'm using an E38 from a 2013 Silverado 5.3, trying to make it work with a T56 transmission. The OS is 12653674. I'd really like to find this OS from a manual car (2013 Camaro?) but I dropbox doesn't have one and I can't locate it.
    When I try to engage the solenoid in Bi-Directional mode, it tells me that it's not a valid output.
    Does anyone know what to change in the Silverado OS to enable reverse lockout? The Silverado uses the same X2-11 output for the AFM Lifter 2 shutoff. I've disabled the AFM but I don't know how to enable the Reverse Lockout Solenoid control. Any suggestions?
    Or...does anyone have this OS from a manual car so I could just do some segment swaps?
    Tom
    Did the 5.3L ever have a manual transmission option on anything? There is so much in the background with the calibrations when dealing with auto vs manual, starting with a base manual trans calibration is by far the ideal way to go.
    Dec 2019
    I'm not aware of a 5.3L manual (at least in the US). I agree that starting with a manual cal would be ideal but I've had a hard time finding one. I want to keep the VVT, which complicates it a little. What I'd really like is to keep the AFM, but I don't think anyone has solved that for a manual trans yet (I'd band aid the reverse lockout if I could keep AFM).
    Keeping VVT is going to makes this much more complicated, I don't believe GM ever made a factory V8 + manual + VVT (+ AFM/DOD) combo so you're going to have to piecemeal things together.
    The 2013 Camaro auto file in the DropBox is the same OS as you have now, 12653674. It looks like GM used separate OS' for auto vs manual, so can't get away with a segment swap unfortunately to solve the auto vs manual portion.
    As you mentioned, the AFM/DOD pin also controls reverse lockout, so you're going to have to give up one or the other. You'll have to figure out which is more important to you to keep, if the only issue you have currently is the reverse lockout solenoid, may be easier to keep what you have.
    Dec 2019
    I’d give up the manual lockout solenoid to keep the AFM, but I’ve heard that the AFM needs a CAN signal from the TCM to work...has anyone else heard otherwise?
    What your wanting to do isnt something as simple as changing some tables. It most likely cant even be done using efi live or any tuning software due to hard coding in the back ground. AFM is horrible and the lifters will fail, its just a matter of when they will fail. There is no way I wold go out of my way to keep AFM when by deleting you can gain hp and fuel mileage and as a bonus a lifter wont break and take out your engine.
    Dec 2019
    I know there are some very strong opinions on AFM and I appreciate your advice. I also know it’s not simple, and I’ve all but given up on it (although I haven’t given up on VVT). I was just wondering if there was anybody out there with the knowledge to make it work.
    I can probably get it to work BUT I highly doubt you would want to pay for something one off like that.
  1. VZ E38 Reverse lockout
    By Shelby in forum E37, E38 & E67 PFI ECM's
    Last Post: July 20th, 2017, 10:31 AM
  2. Replies: 22
    Last Post: January 29th, 2013, 06:57 AM
  3. Reverse lockout T56
    By JuhaniLS1 in forum Gen IV V8 Specific
    Last Post: December 6th, 2011, 02:42 PM
  4. Conversion of Auto to manual.
    By odd boy in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 18th, 2009, 09:58 AM
  5. camaro auto to manual conversion
    Last Post: March 26th, 2007, 12:15 AM
Tags for this Thread
