Results 1 to 10 of 11
Thread: Can someone help find the issue from datalog?
    Oct 2020
    Default Can someone help find the issue from datalog?
    Hello,
    I am working (slowly) with a mail order tuner. It is for a free re-tune, which is why it is slow going. I sent them the first datalog, and evidently it is way out from what they expected.
    They first thought it might of been a vacuum/ boost leak, so I bought a smoker and could not find anything.
    Then they were asking about the fuel system, which I described it back to them and waiting on a response back now.
    Vehicle info:
    2004 Sierra 1500 4x4
    wired up "stand alone"
    6.0l lq9
    4l80e trans
    2.9l Whipple supercharger
    ported heads
    1.875" headers
    3" dual exhaust
    90mm throttlebody with xlink adapter
    fuel system is 63lb/hr injectors @ 43.5psi- running a boost referenced fuel pressure regulator, set at 58 psi with the line disconnected.
    cam specs.
    Intake Duration at .050 Inch Lift:227
    Exhaust Duration at .050 Inch Lift:243
    Intake Valve Lift:0.614
    Exhaust Valve Lift:0.624
    Lobe Lift Intake:0.361
    Lobe Lift Exhaust:0.367
    Lobe Separation:114
    Intake Centerline:109
    So if anyone can look at this, and suggest any issues that could be causing me problems- it would be appreciated.
    thanks,
    Josh
    Jun 2019
    What is the issue you are having?
    Oct 2020
    Hello,
    The issue is, the prson tuning it thinks the data is too far off. Allow me to quote them.
    This is the first response I got after srndi gthrm the datalog-
    "Is there any chance that you have a sizable boost leak? It is appearing as a vacuum leak outside of boost and then goes excessively rich in boost."
    After that, I bought a smoke machine and hooked it up to a vacuum line to make sure everything was sealed. Afterwards I let the tuner know there were no leaks and received this in response.
    "It's very strange data. Perhaps there is something else amiss. What fuel injectors are you running and are you still running it as a returnless?"
    Responses are taking about 2 weeks from them, so I am trying to track down the issue myself (hopefully with help from this forum).
    Thanks,
    Josh
    Jun 2019
    My first guess would be that the injector data is incorrect. If you have a copy of the tune I can take a quick glance at it and see how its set. PM me the tune.
    Oct 2020
    I am at work currently, but can send tune file later.
    I did look at the injector flow rate table, and it had the same value for each cell- which I believe is correct. I eant to say they were calculated at 73 lb/hr?, which a calculator I found on Google seemed to agree with.
    Jun 2019
    Who makes the injectors?
    Oct 2020
    I believe they are Siemens Deka
    Oct 2020
    Here is the tune file.BlowerTune.ctz
    May 2014
    100% need to confirm what injectors you have, and then confirm injector data before really digging much further, IMO.
  1. Replies: 40
    Last Post: December 11th, 2016, 08:47 AM
  2. Unable to Datalog with Autocal
    By derek1387 in forum AutoCal
    Last Post: April 25th, 2016, 09:39 PM
  3. Datalog with huge numbers
    By Illegal Vette in forum Gen III V8 Specific
    Last Post: April 15th, 2016, 01:43 AM
  4. datalog
    By desltech in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 28th, 2014, 03:54 PM
  5. AutoVE datalog filters
    Last Post: March 27th, 2008, 10:07 PM
