Results 1 to 2 of 2
Thread: Weird autocal error LML
    Feb 2020
    Question Weird autocal error LML
    I cannot figure out what this means. When full programing goes through all the normal processes and ends with this screen - OK 733 ER 5
    any help?
    Quote Originally Posted by mdfcustoms View Post
    any help?
    It's not really an error, it is just the BBX Statistics that may be optionally shown at the end of a read or flash. The OK value is the number of messages that went through without any problem, the ER (error-retry) value is the number of messages that were detected as containing faulty/corrupt data. Any messages with faulty or corrupt data are retried up to three times before the read or flash is aborted.
    If the read is successful (i.e. all check sums show as green ticks when you open the tune file) or if the flash is successful then all the ER messages were successfully retried/recovered.
    If the read or flash fails you can use that display to see the ratio of OK to ER messages sent during the read/flash process. A rule of thumb is if ER is greater than about 5% of the total messages then there may be a network fault in the vehicle.
    With only 5 retries in 733 messages that's a failure rate of only 0.6% which is pretty good and nothing to worry about.
    That display can be switched on/off using this option:
    It says (FS V2 Only) but obviously that option is valid for AutoCal as well.
    Last edited by Blacky; November 5th, 2020 at 12:17 PM. Reason: 0.06% -> 0.6% (I can't do math)
  1. Lml flashing problem $0331 autocal
    By swampytyme in forum AutoCal
    Last Post: July 17th, 2019, 12:58 PM
  2. Replies: 3
    Last Post: October 29th, 2017, 01:06 PM
  3. Weird OBD Scan on a 2016 LML
    By GMC-2002-Dmax in forum Diesel
    Last Post: March 30th, 2017, 08:15 PM
  4. error $0185 for lml
    By pavetim in forum Black Box Logging
    Last Post: September 28th, 2016, 12:13 PM
  5. ?Lml flashscan v2 or autocal? Limitations?
    By bighuey in forum FlashScan V2
    Last Post: April 14th, 2015, 03:48 AM
Tags for this Thread
