Page 12 of 13 FirstFirst ... 210111213 LastLast
Results 111 to 120 of 127
Thread: Installing the V7.5 Software
  1. #111
    Jun 2011
    Just installed on my windows tablet without issues so it must me my pc doing something screwy. What is the best way to completely wipe efilive off my pc and start fresh? Only thing I care to keep are my scripts which I can make a backup and move over to the fresh installed folder. That's about all I know to do unless you all got another option.
    Sent from my SM-G960U using Tapatalk
  2. #112
  3. #113
    But obviously for the folder that you are having security issues with - instead of the folder shown in that article.
  4. #114
    Quote Originally Posted by comnrailpwr View Post
    Uninstall V7
    Then delete the registry key: HKEY_CURRENT_USER\Software\EFILive\V7.5
    Then re-install V7
  5. #115
    Jun 2011
    Checked permissions. All hass full access. Deleted registry. Re installed and same issues. I can right click in the user config folder and creat new text documents so my account does have access to write to the folder. I checked and made sure their are no encryptions of any kind. Next step I guess is install software on my external hard drive and see if that works.
  6. #116
    Can you right-click on the desktop shortcut for EFILive V7.5 Tune and add /l (space, forwards slash, lower case L) to the command line and click [OK]
    Then start the V7 tune tool software via the short cut using the right-click->"Run as administrator" option), that should create a log file called: \Program Files (x86)\EFILive\V7.5\StartupLog.txt
    After you get the error, take a look in that file using Notepad and see if any additional information in that file helps to identify the cause.
  7. #117
    Like this:
  8. #118
    One other thing to try, if you have virus checking software, try disabling it (temporarily) and see if that allows EFILive to create/save the files that it needs to.
    We have had other customers report problems caused by antivirus software preventing files from being created/updated.
  9. #119
    Jun 2011
    Nailed it paul. Thank you. Something with my antivirus software (free version of avast) is causing the issues. what is weird is it's the same I have had for several years. it appears to be affecting the pc differently now that I upgraded my machine to windows 10. Any recommended antivirus software?
  10. #120
    It's not cheap, but...
    https://www.eset.com/nz/home/antivirus/
    That's the New Zealand link, you'll probably want to go to the link for the US version - which I can't easily get, since it keeps redirecting me to NZ.
    Doh!
  1. Installing the V8 Software
    Last Post: April 18th, 2022, 11:39 AM
  2. Installing new ECM - What to expect??
    By juscruzn in forum Duramax LLY
    Last Post: February 1st, 2010, 09:46 AM
  3. installing drivers for new 7.5.5 v2
    By Adam Calley in forum Gen III V8 Specific
    Last Post: April 15th, 2009, 08:12 AM
  4. Installing new firmware
    By black346 in forum FlashScan V2
    Last Post: March 29th, 2007, 09:02 AM
  5. Installing Custom OS
    By oztracktuning in forum Custom Operating Systems
    Last Post: April 27th, 2006, 09:58 PM
