Page 7 of 8 FirstFirst ... 5678 LastLast
Results 61 to 70 of 71
Thread: lc1 BEN factor for auto ve leaning out afr
  1. #61
    rats, I did forget... ...sorry.
  2. #62
    rats again, the zip file is on the laptop I left at work...
  3. #63
    Sep 2017
    any luck finding those files? I switched the data on my map and seemed to get better data. I think the temperature changes I am going through right now with the seasons changing aren't really helping any. I had a question on what to do with my new data after I'm done, I've been changing the backup ve table due to my 98 pcm, but when I set my MAF back to active it won't be looking at the backup table anymore correct? do I need to copy the backup table into the main table and just blend the high res cells with the other ones?
  4. #64
    Thanks for reminding me... hold on a sec...
  5. #65
    See attached .zip file... if you look in it you will see where all the parts go...
    it includes these files:
    - .pid file to selects the pids of interest
    - .map for VE table using WO2BEN
    - .vdb virtual dash (see dash B charts)
    - calc_pids.txt from above.
    Here's some files for the scantool, unzip them to their correct folders under c:\user\<you>\Documents\EFILive\V7.5.
    Then in the scantool, open up VDash chart LS1B-0001-m, and open up map B0101-CALC-WO2BEN.
  6. #66
    Sep 2017
    awesome, I'll download and install them when I get home after work today. what should I do about my Backup ve table and getting the computer to use it?
  7. #67
    When you re-enable the MAF, the PCM will use MAF and VE as follows:
    - when RPM is above B0120, PCM uses MAF-only.
    - when RPM is below B0120, PCM uses MAF for steady state airmass, and uses VE for transient airmass.
    B0120 is set to 4000 RPM from the factory.
    This means, after you get your Backup VE corrected, you have to populate the Main VE from this... and then you have to correct the MAF is the same manner (disable VE by setting B0120 to 400 or less)(and disable CL/LTFT/STFT).
  8. #68
    May 2007
    Do this: set B3601 to 9.7 ( there are kits to measure alcohol % content in gasoline, then you can cross-reference it to the stoich AFR to use).
    Then let's take a look at your calc_pids.txt file, post it here, it's located under c:\user\<you>\Documents\EFILive\V7.5\User Configuration.
    im interested in changing mine to 10.7 for 70% ethanol we get consistently in south Louisiana. my Ben factor is way off so I only use Lambda but have to manually change each cell.
    im ignorant when it comes to the programming side of efi live.
    2000 NBM trans am.
    427 Dart ship block,Lme ported Ls7 heads 12.5 compression
    246/262 .730/.712 112+4 low lash solid roller
    Rmvb 4l80 with transbrake, 8" FTI converter
    12 bolt Moser rear end with 4.10 gears
  9. #69
    Quote Originally Posted by Aint Skeered View Post
    Post some screenshots of BEN map.
    Are you editing VE table or MAF table (and are you disabling the other table)...?
    Are you disabling trims (LT, ST, and OL)...?
  10. #70
    May 2007
    Ve table.
    Im open loop speed density
    2000 NBM trans am.
  1. V8 Scan - Calculated Ben factor
    By Tre-Cool in forum Tutorials
    Last Post: September 12th, 2017, 06:34 PM
  2. Replies: 30
    Last Post: April 8th, 2017, 10:59 AM
  3. Ben Factor Question
    By EVI in forum E37, E38 & E67 PFI ECM's
    Last Post: March 17th, 2010, 11:01 PM
  4. Auto VE Ben Factor
    By shane in forum Gen IV V8 Specific
    Last Post: June 20th, 2008, 11:34 AM
  5. Logging BEN factor with March 20th Beta?
    By Goldfinger911 in forum FlashScan V2 BB Logging
    Last Post: March 23rd, 2008, 06:03 PM
