Thread: '10 Camaro L99 E38 ECM Throttle Closing during shift
    Aug 2020
    Default '10 Camaro L99 E38 ECM Throttle Closing during shift
    Has anyone experienced this problem?
    As soon as the car shifts, the throttle goes from ~84% to about 42% for a duration of about 0.4 seconds in the 1-2 shift, then OCCASIONALLY does this for a shorter amount of time in the 2-3 shift.
    Overrev RPM set at 6800, shift RPM set at 6400~6500 (I have tried 6000 and 6300 too). This did not occur with the original OEM tune, but as we are increasing the HP/TQ the problems seems to get worse.
    The TQ limits in each gear is set to 1000 lb. ft.. The engine is showing about 325ish.
    Any assistance that you can offer will be greatly appreciated.
    https://imgur.com/6c5qLoA
    Lifetime Member izaks's Avatar
    Aug 2003
    Check the setting of B0517. Try setting it to no.
    2011 VE SSV 419 + CAM + Whipple 2.9FF SC + PPV front struts + Bilstein rear shocks + 6L90E with single piece carbon fiber prop
    Aug 2020
    Quote Originally Posted by izaks View Post
    Thanks for your response. I have the TQ reduction set to "by spark option" with all other settings indicated with "no".
    Any other suggestions?
    https://imgur.com/hP8D4Er
    Aug 2003
    Only thing I can think of is Traction Control ?
    Aug 2020
    As far as I know, I have all the TQ limits for traction control set very high. There is a chance I might be missing something in one of the settings, but I don't quite know where else to look.
    Aug 2018
    Post up the trans and engine file. So I can compare it to what I do to those.
  1. Looking for stock ECM file for '15 Camaro E38, OS: 12658778
    By Turbosaurus in forum Gen IV V8 Specific
    Last Post: May 3rd, 2020, 01:04 AM
  2. Camaro L99 read diff from 3.27 to 3.90
    By horst in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: December 9th, 2013, 05:31 AM
  3. 69 camaro e38 ecm compatibility question
    By EVI in forum E37, E38 & E67 PFI ECM's
    Last Post: April 11th, 2012, 11:23 AM
  4. Reducing TM in a 2011 Camaro L99??
    By BowlingSS in forum E37, E38 & E67 PFI ECM's
    Last Post: December 6th, 2010, 01:26 PM
  5. 2010 Camaro L99 vs a 2011 Camaro L99 Tune.
    Last Post: December 6th, 2010, 10:33 AM
