Results 1 to 5 of 5
Thread: V2 and PLX wideband?
    Oct 2010
    Default V2 and PLX wideband?
    Anybody successfully get a PLX wideband to show up using the serial port in efilive. I for the life of me cannot. I have the SM-AFR and it has a Tx port which is a 3.5mm stereo jack serial output. I have the cables i used for my innovate and that works great for my innovate, only difference for the PLX is i have to use a 2.5mm to 3.5mm adapter. Any ideas i cannot get this thing to show up
    Could Tx and Rx be accidentally swapped?
    Oct 2010
    Dont think so cause my wideband innovate works fine. The only difference between innovate and plx is i need to use a 2.5mm to 3.5mm adapter on the plx. I will play and see if i can get analog to show up, somewhere i read analog updates faster than efilive anyways so serial no better. Not sure how true that is though
    Mar 2009
    The PLX requires adding in a ttl to rs232 serial port to work.
    https://forum.efilive.com/showthread...-SM-AFR-Serial
    Senior Member SV8346's Avatar
    Nov 2007
    PLX SM AFR TX & RX Ports are for daisy chaining to other PLX Devices.
    2016 RG Colorado 2.8TD
  1. PLX Wideband doesn't match?
    By 2ktransam in forum General
    Last Post: March 8th, 2013, 09:01 AM
  2. Any way to dampen the PLX wideband output?
    By lsx523 in forum Gen III V8 Specific
    Last Post: February 1st, 2010, 07:58 AM
  3. Auto ve and plx wideband?
    By mvnvltn in forum Gen IV V8 Specific
    Last Post: December 31st, 2008, 07:20 AM
  4. PLX wideband compatibility question
    By robz in forum General
    Last Post: August 4th, 2008, 10:54 AM
  5. PLX Wideband SM-AFR
    By Rhino79 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 22nd, 2006, 02:46 AM
