Results 1 to 5 of 5
Thread: Can I read live data V2?
    Apr 2021
    Default Can I read live data V2?
    I cannot find info on reading live data on my V2 box, is it not possible?
    Nov 2005
    The option to display data sits below the record data option on your V2.
    Follow the instructions here, and just switch out the F1: Record for F2: Display. https://service.efilive.com/kb/artic...2-data-logging
    Cindy
    Apr 2021
    Cindy
    THANKS, I will give that a try!! But after reading the instructions it looks like all I can do is record, not see live data as it happens, heck I have a $100 code reader that will give me at least some of the live data
    You can view the data live that you are recording on the V2 device
    Jim
    2000 LS1 M6, No EGR/Air/PS/CATs. TR230 Cam, COS3, OLSD, LC1 Wideband fitted, Procharger P1SC, 2 Bar MAP, Siemans Dekka 60Lb Injectors.
    All wrapped up in a 2000Lb AC Cobra Replica
    Doing BBL (black box logging), FSV2 displays live real time data on its LCD while recording.
  1. Arduino to read and process J1850 VPW data
    By derkscustomcars in forum Petrol / Gas
    Last Post: July 12th, 2018, 05:42 AM
  2. Cant see live data please help
    By byrdman11 in forum General
    Last Post: October 16th, 2013, 09:06 AM
  3. Autocal Read Error $0101 No data received
    By firehawk in forum AutoCal
    Last Post: April 14th, 2013, 10:36 PM
  4. Data Logging, offset Boost Pressure to Read Correctly in vDash
    By BioHazard73 in forum Black Box Logging
    Last Post: September 25th, 2012, 12:58 PM
  5. Converting Ford style injector data to data useful to EFI Live.
    By JOHNBOY in forum General (Petrol, Gas, Ethanol)
    Last Post: May 11th, 2012, 06:19 AM
