Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: 4L60E Transmission Torque Reduction during WOT
    Jan 2017
    joecar - that's exactly how i got to this point. I read everywhere that you should set the times to 0 when you have a shift kit and then use TR to soften the shifts - which was not working.
    I should have some time later this week to test 0.001s and 0.01s.
    Jan 2017
    joecar - Below is a summary of all the tests that I've run.
    Tune Entered: Desired Shift Time (s) After Save/ Re-open: Desired Shift Time (s) Shift Tested Torque Reduction Work? Notes
    0 0 1-2 NO tested multiple times, all had no TR
    0 0 2-3 NO
    0.001 0 1-2 YES TR worked even though the tune showed 0 sec after saving and re-opening
    0.01 0.0125 2-3 YES
    0.1 0.1 1-2 YES
    0.2 0.2 1-2 YES
    0.2 0.2 2-3 YES
    0.6 0.6 1-2 YES
    recrit, Thanks, appreciated
    The Save/Reopen values you see are due to the fixed point binary representation not being able to represent all fractions (so 0.0.125 is the closest value that 0.01 can be represented as).
    The 0.001 -> 0 that you see is not a zero, you need to increase the display precision and you will see that is is something like 0.000125.
    Jan 2017
    joecar, that makes sense now for the "Save/Reopen values".
    I set all shifts to 0.2s now and everything is working as expected now. Thanks again!
  1. Torque reduction
    By Boosted GMC in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: July 4th, 2009, 07:42 AM
  2. TCM Torque Reduction Q
    By Cougar281 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 30th, 2007, 07:02 AM
  3. Removing Torque Reduction...what 4L60e mods??
    By MrZ71man in forum General (Petrol, Gas, Ethanol)
    Last Post: November 13th, 2007, 04:21 PM
  4. Torque Management reduction
    By Redline Motorsports in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 30th, 2007, 11:28 AM
