Results 1 to 10 of 17
Thread: No communication with PCM
    Jan 2007
    Default No communication with PCM
    Hey guys
    Been a loooong time.
    Pulled my PCM apart to powdercoat the housing….and somehow in the process I can no longer connect to the PCM via efilive.
    I can connect directly to the installed road runner via the usb on the pcb and ‘tunercats’.
    Any thoughts?
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
    Hi Howard,
    How're you doing, it's been a while.
    Are you using V5...? I thought you used V7.
    From V7 scantool, connect (round green button), and copy/paste the log text from the log tab.
    Jan 2007
    Gidday mate….it has been a very long time. Lots has happened since I was last here.
    Glad to be playing in this pond again.
    Yes…using V7. I’ll do as you suggested tomorrow when I get home. thanks
    I can flash an OS and Cal to the RR via either EFILive or TC….and can read it and all is good….but still same issue.
    Fuel gauge goes off scale (which apparently means no or corrupt cal) and the truck won’t fire….just cranks over.
    Howard
    DUCT TAPE.
    Jan 2007
    Where is the ‘log’ tab located? I don’t see it?
    Howard
    DUCT TAPE.
    Quote Originally Posted by hquick View Post
    Ah, I meant the Console F6 tab.
    Jan 2007
    Haha
    Howard
    DUCT TAPE.
    Jan 2007
    You had me for a bit ��. I thought.. It’s been a while…am I that rusty. I have a screen shot…not sure how to post it?
    Howard
    DUCT TAPE.
    You can copy/paste from the Console tab to here.
    Or if you have a pic of it, click the Insert Image (looks like a tree thru a window).
    Jan 2007
    Let
    Howard
    DUCT TAPE.
    Is the PCM getting battery power ok...?
  1. E39 ECU/PCM lost communication with SIDI VE V6
    By 3L SIDI in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: September 8th, 2013, 12:48 PM
  2. No Communication After Reflash?
    By Yukon 400 in forum Custom Operating Systems
    Last Post: October 22nd, 2008, 09:18 AM
  3. no communication w/ roadrunner...
    By rubbersidedown in forum RoadRunner Real-Time PCM Emulator
    Last Post: August 3rd, 2008, 11:42 PM
  4. Sometimes communication hangs
    By Ira in forum FlashScan V2 BB Logging
    Last Post: January 2nd, 2008, 08:29 AM
